Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th February 2008, 09:08 AM   #1
gmikol is offline gmikol  United States
Default Opinions on Mic Pre-Amp circuit
Hi everyone--
I'm trying to design a balance mic preamp circuit for myself, and I need some feedback on a couple of different options for the last stage which is going to drive the line-in of my sound card.
In the first one, the drive stage has fixed gain, which I moderate with an attenuator. The second one uses a pot in the feedback to adjust gain.
Another question I have is regarding noise. Is it better to have more gain early?
Right now I have the circuit drawn with OPA2134. I've been considering OPA2228 or perhaps LM4562. Can anyone recommend any other good, low-noise opamps for a design like this?
Also, I haven't started the PCB layout yet, and I don't really have any experience with high-gain circuits like this...any tips or tricks on the layout side?
Thanks for everyone's help--
Greg
Old 10th February 2008, 09:09 AM   #2
Here's the other design option with a pot in the feedback to set gain.
--Greg
Old 10th February 2008, 09:32 AM   #3
Gordy is offline Gordy  United Kingdom
I have never designed one, but these guys have...
http://www.prodigy-pro.com/forum/viewtopic.php?t=16909
Old 10th February 2008, 10:09 AM   #4
I would be tempted to replace IC1a & b with the 2228 option.
The input resistors, r10 to r13 inclusive, should be matched to better than 0.1% and preferably <=0.01%.
Use a very low noise regulator for the power supply.
regards Andrew T.
Old 10th February 2008, 06:24 PM   #5
Holy **** that's a lot of info!!! How did I not find that one while I was searching? It's gonna take me weeks to go through it all.
While I'm reading...anybody out there care to comment on which of my 2 options is a better choice, and if the gain structure is OK? I've forgotten what little I learned about noise analysis.
This thing is going to be battery powered with 9.6V NiMH batteries, 4 in total. 2 for phantom power, and 2 for the opamp supplies.
--Greg
Old 10th February 2008, 06:51 PM   #6
Minion is offline Minion  Canada
You know you can get pretty much that whole curcuit in an IC (Ballanced Differential input and unballanced output) useing a THAT1510 or a INA217 and it will have lower noise and the Gain can be set with either a fixed/switched resistor or a Gain pot...It would save money as these Chips are less that $5 each and it will save in PCB size...I have built Basic Mic preamps with these Chips that were less than 2in Square and totally quiet and have a Max gain of 66db (72db if you add a ballanced line driver or Output transformer)......
Cheers
Old 10th February 2008, 10:37 PM   #7
Originally posted by Minion
You know you can get pretty much that whole curcuit in an IC (Ballanced Differential input and unballanced output) useing a THAT1510 or a INA217....
Yeah, I know about those chips. I've got a design using the INA127 on the drawing board as well.
This is as much about learning for me as it is anything else. So I need to go down the "wrong way" path and see where it takes me.
Wrong Way #1 (unpublished): 100K/20K feedback resistors and a TL072 with 47dB of gain makes for a poor mic preamp.
--Greg
Old 11th February 2008, 08:16 AM   #8
tINY is offline tINY  United States
I bet that the TL072 pre amp could be made a lot better with an impedance matching transformer, but that's a $100 option for a good one....
Is there some reason you want 18v phantom power? - seems to me you could stack the batteries and at least get 36v without trouble.
-tINY
Old 11th February 2008, 04:30 PM   #9
Since I'm using 9V batteries, that's 2 for phantom power and 2 for the opamp supplies. Something in the back of my head is telling me I can't hang the mic power across the +9 and -9 rails without bad things happening. Am I wrong?
Aside from a lower Max SPL capability, what's the downside of a lower phantom supply? From doing some reading, I realize that the 6k8 resistors should be reduced to something like 1k2.
If I *can* hang the phantom supply across the +9 and -9, then I can use only 2 batteries total instead of 4.
--Greg
Old 12th February 2008, 01:48 PM   #10
PigletsDad's Avatar
--Greg
Depends on the mic. Not all mic preamps are happy with funny voltages, some may simply move outside there normal bias points and be grossly distorted - for example, if it is a valve mic, bad stuff may happen unless it gets the expected 48V.
I cannot see any harm in stacking the phantom voltage on top of your +9V rail, which would get you up to 27ish volts.
Need opinions about this tube circuit gaetan8888 Tubes / Valves 27 12th July 2009 11:36 AM
I/V + Output opinions needed for this circuit georgehifi Digital Source 8 3rd April 2007 03:14 PM
Trouble with speaker protection circuit (Randy Slone's circuit) whalefat Solid State 3 13th April 2005 10:13 AM
Wanted: Opinions On SPDIF Circuit Configuration fastcat95 Digital Source 5 11th January 2005 05:26 AM
Opinions of tracking regulator circuit. G Solid State 1 30th September 2002 10:41 AM
Page generated in 0.12194 seconds (82.05% PHP - 17.95% MySQL) with 11 queries
