| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Oops!
Stay tuned...
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#12 |
Part 2a, ( I'm in a bit of a rush!) - Testing
Make another cup of your favorite beverage. Whilst it is brewing, get together a line level signal source, a mic and a powered monitor/poweramp + speaker combination. The aim now is to check every single control on the desk. For each channel, start with the line level input and go through checking every single knob and switch, along with all the routing options to auxes and subgroups, as well as the main left and right. Make notes as you go on any faulty or noisy parts. This does involve a lot of plugging and unplugging on the output side, but is required to to throughly check the desk. When you have finished each channel, go round the back and wiggle the input connector to check for loose connections, then check the channel with the mic, (you can do this the other way around, but using line level for most of the testing saves the voice, and the sanity of others in the room with you). Finally, pick up the desk from the bench and drop it back down from an inch or so high This is a great indicator of any dry joints or loose connections. You should now have a list of issues, and we'll look at those in part 2b.
#13 |
Many thanks for all input so far.. the hot water is boiling now, so I think it's a tea for me and then the pile of knobs on the table is going in a bucket to soak off the same grime I have all over my fingers after removing them all.
Thing I'm most worried about is that due to the ridiculous humidity here the powder coat/paint finish is actually peeling away in places...I don't really want to be removing it any further... Looking forward to any further installments.. |
#14 |
Well, you can always use a cotton bud for the fragile bits, but they are going to fall off sooner or later anyway, and the grease and sweat trapped underneath will continue to lift more and more of the paint unless removed.
Do you see why it's nice to start servicing with a clean desk now?
#15 |
Any suggestions for a readily available cheap product for cleaning coonector contacts?
#16 |
Isopropyl alcohol is a good cleaner, but the Caig Deoxit I mentioned earlier on both cleans and lubricates the contacts. It's not a cheap as alcohol, but it is a longer lasting solution.
Peace, Dave |
#17 |
yes, but specific products such as deoxit aren't available here.. for that reason I was asking more for widely available generic products that would do the job..
Will give isopropyl a try... A search threw up suggestions of WD-40, is this really sensible/effective? |
| speaker preventative maintenance. | speekergeek | Multi-Way | 11 | 11th March 2012 04:22 AM |
| sansui 1000a maintenance | dognut | Tubes / Valves | 1 | 18th February 2009 12:51 AM |
| Old School Maintenance | Wyloch | Solid State | 2 | 22nd June 2005 02:22 AM |
| oracle delphi maintenance kit | Daniel-A | Analogue Source | 0 | 6th March 2005 11:41 PM |
| Calrec - AMS VCS desk and AMS-Neve Libra Live desk | chrisbeech2 | Solid State | 0 | 15th January 2004 08:07 PM |
| Page generated in 0.10207 seconds (76.71% PHP - 23.29% MySQL) with 10 queries |
