Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th January 2008, 10:59 PM   #1
Default 2 channels to 1 crosstalk
I have 2 audio channels that i am trying to merge into 1. The problem i am facing is that they share a common ground, so when isolating one signal it still picks up crosstalk from the other signal. My main goal is to have 2 separate outs of each channel and a mono mixed out.
Old 19th January 2008, 01:42 AM   #2
Quickest way would be to build a buffer amplifier for each channel. No gain, just provide a hi impedance between the two inputs, this should pretty well block crosstalk. If you aren't too picky, using a couple of opamps, or two channels of a single opamp, setup for a gain of 1, tying the outputs of the opamps together, and putting a small series(500-100 ohms) resistance between the opamp outputs and the summing point should work for you.
Peace,
Dave
OPT Grounding / Crosstalk draperphoto Tubes / Valves 0 5th October 2008 12:07 AM
Interaural crosstalk eStatic Everything Else 3 28th February 2008 04:53 PM
Crosstalk cancellation Prune Digital Source 10 19th January 2006 02:19 PM
A question on crosstalk sardonx Solid State 6 21st June 2004 11:45 PM
Crosstalk cancellation Prune Everything Else 0 31st March 2004 12:11 PM
Page generated in 0.06666 seconds (65.83% PHP - 34.17% MySQL) with 10 queries
