| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
As a general guide, If I put bras plating on my PCB tracks how much would this increase the current handling of them?
Plating is about 0.5mm thick, tracks are approx 1cm wide Is there a better way I can increase with power handling of the tracks without making them wider? |
#2 |
Solder a bus bar to them. You can use a piece of heavy gauge copper wire for a bus bar.
MR
Keeping an open mind since 2002... |
#3 |
Electrons are yellow and more is better!
1 cm copper traces, 35 µm thick can take 30-40 A without fusing the traces. 70 or 105 µm can you also test. How many amperes do you have in your circuit?
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
About 75 @ full load.
I have a fair bit a 1mm copper winding wires. If i solder it onto the traces every cm or so along with iss act as the same thing right? |
#5 |
What is it? An amp? Think also that the half current will flow in all traces except for speaker output (if it's an amp). 70-105 µm will do the trick for you also soldering extra copper wire.
| Power supply:Universal AC input/ Full range,High Efficiency, and High reliability | hang | Vendor's Bazaar | 12 | 24th July 2009 04:46 AM |
| Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. | kimbal | Tubes / Valves | 4 | 11th May 2009 09:05 PM |
| high frequency high voltage power supply... | moray james | Planars & Exotics | 6 | 23rd July 2008 08:57 PM |
| Page generated in 0.08423 seconds (72.65% PHP - 27.35% MySQL) with 10 queries |
