Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
how do i fix my subwoofer
Old 3rd January 2008, 02:34 PM   #1
wanky is offline wanky  Australia
Unhappy how do i fix my subwoofer
i bought a home speaker system second hand and it has really bad distortion throught the subwoofer channel, all the other speakers work fine. I opened it up and found 2 bulging and dried up capacitors with my ESR meter so I replaced them but the problem still remains. I dont know much about amps what else should i look for with this distortion .f rom what I see its using LM1875T amps for the speakers and using IRFP150 & IRFP9150 for the subwoofer, could these be stuffed? how do i test them?
thanks for help
Old 3rd January 2008, 07:59 PM   #2
DSP_Geek is offline DSP_Geek  Canada
Recheck the other electrolytics, especially the large one beside "BAD CAP HERE". If two already went west, likely some others are on their last legs. You might also want to verify the solder joints under the IRF devices, as they looked a bit dodgy to me.
Old 5th January 2008, 04:06 PM   #3
i replaced the cap but no difference. i measures voltages of the mosfets while playing audio and they dont change at all
IRFP150 Vgs 3.2v Vds is 49.4v
IRFP9150 Vgs -2.9v Vds -48.9v
should the voltages be the same? also shouldnt gate voltage go higher than that? plz help im trying to learn
how do i fix my subwooferHide this!Advertise here!
subwoofer under bed Potato42 Subwoofers 7 13th January 2009 02:21 PM
subwoofer project, which subwoofer? Davlaf Subwoofers 12 9th November 2006 03:59 AM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
I need help with subwoofer deisign: HUGE inexpensive subwoofer hottyson Subwoofers 16 4th May 2004 03:51 AM
Copyright ©1999-2017 diyAudio
