Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd January 2008, 12:18 PM   #1
jogas is offline jogas  Italy
Default -200 VDC regulator
I need to reduce a -270 VDC down to -200 at 20 mA.
Is there any three pin component available?
I only found a VB408 that is a positive regulator
Thanks in advance for your help
Giuseppe
Old 3rd January 2008, 12:21 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
a fat 3k5 resistor maybe? 2 - 5W
70/3500 = 0.02A
Old 3rd January 2008, 12:40 PM   #3
.... I do need a very precise and stable and current independent -200VDC...
Old 3rd January 2008, 01:12 PM   #4
theAnonymous1's Avatar
Is it not possible to use two LM137HV? Use one to pre-regulate down to around -235v and the other to drop down to -200v.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 3rd January 2008, 01:39 PM   #5
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Default Re: -200 VDC regulator
Have you thought about just using a zener (or a string of zeners), resistor(s), and pnp transistor? A 70V drop across a transistor sinking 20mA is only 1.4W. You could also put a resistor in series with the collector to reduce the transistor's dissipation.
Brian
Old 3rd January 2008, 01:58 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Re: -200 VDC regulator
Giuseppe
If your raw supply is floating you can use a pos regulator. Just ground the pos terminal and use the common terminal (which normally would be grounded) as the neg terminal. Works like a charm.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 3rd January 2008, 01:59 PM   #7
SY's Avatar
I'd use a Maida regulator with a 337 and either a HV PNP bipolar or HV p-channel MOSFET. Simple, stable, low output impedance, low noise. And reliable.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 3rd January 2008, 02:06 PM   #8
Thanks for the answers, yes, the easiest way is to use apositive regulator with the output grounde...
SY what is a maida regulator?
Giuseppe
Old 3rd January 2008, 02:11 PM   #9
SY's Avatar
Poke around National Semiconductor's site. There's a nice paper by Michael Maida on using a HV bipolar to limit the voltage across a 317-type regulator. I think the paper is Linear Brief LB-47. This paper only shows positive regulators, but by using PNP (or p-channel FET), a 337, and turning around the diodes, you can make a negative regulator.
Or you could use the positive regulator as published inserted in the ground leg of your raw supply.
HV Regulator habsrock93 Tubes / Valves 3 21st October 2008 07:15 AM
Zener regulator with "integrated" pre-regulator 00940 Power Supplies 17 22nd July 2008 05:11 PM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Page generated in 0.09300 seconds (79.15% PHP - 20.85% MySQL) with 10 queries
