The Burr-Brown "Discontinued Products" sheet lists the OPA602AM as a replacement for the 3308/12C.
I found the discontinued products sheet here:
http://www.ortodoxism.ro/datasheets/BurrBrown/mXxsttr.pdf
jacco vermeulen said:Unisonic UTC3308
Unisonic is a modern dual opamp with single supply, that BB is single opamp with dual voltage supply.
gootee said:The Burr-Brown "Discontinued Products" sheet lists the OPA602AM as a replacement for the 3308/12C.
I think I will try it just for fun. The pcb on the picture is a complete line buffer with discrete output stage inside feedback loop.
Burr Brown, Intech, Analog Devices, Teledyne Philbrick, and others manufactured discrete op-amps. In the 70's, at Intech, I designed and characterized a variety of descrete op-amps and designed production test fixtures. The A-148A is a JFET input op-amp with a Bandwidth of 10 MHz. The 990 discrete op-amp circuit is ventrally identical to the A-148A with the exception of the JFET input and a few improvements.
The RIAA amplifier board has two A-148A’s on a 22-pin Vecotor board. It has been in use for over 42 years.
Dear WSJ,In the 70's, at Intech, I designed and characterized a variety of descrete op-amps and designed production test fixtures.
I have a pair of Intech A-100 and I have not found any datasheet on the web. That's not a problem for building an audio circuit with it, but could you please let me know its max. V+/V- if you know this "beast"? Thanks, Bernard
Old Intech Part Info?
I need to find replacement op amp for Intech A-440. The problem is that I cannot find any specs or the datasheet on the internet. Is there a chance you can post or send me some info for this component?
Thanks in advance
Dear WSJ,Originally Posted by WSJ http://www.diyaudio.com/forums/parts/114219-old-burr-brown-op-amps.html#post3149469
Thanks in advance
Very interesting--do you still have schematics or datasheet for these products? I'd love to see them!
Samuel
- Design & Build
- Parts
- old Burr Brown Op Amps
