Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Recycling Parts is it possible
Old 20th February 2003, 11:26 AM   #1
TomJ is offline TomJ  United Kingdom
Default Recycling Parts is it possible
Is it possible to recycle and re-use compnents from old eqiutment(i.e. television,radios,computers.....). I have a lot of old junk like this that dosn't work and is beond repair yet a lot of the components still work.
Are there any problems with doing.
The resons to me for doing this are fairly simple. firstly it would be a lot cheaper for me just to remove the components + it would be envoiromentally friendly.
Old 20th February 2003, 11:35 AM   #2
Brett is offline Brett
Brett's Avatar
I can't see any problem with recycling old parts, providing the parts are still OK, ie if the unit was faulty before it was scrapped, make sure the parts you recycle are not the ones that caused the fault, or were damaged by the fault condition. I've done it myself before, and have lots of iron in my system that I took from dead amps, as well as tubes, sockets and some passives. Much old gear is simply thrown away because it was replaced with newer and is still working, had a minor fault that was 'too expensive to repair', junked in estate cleanouts etc. If you have a use for the part and it is still safe, it's better than it going to landfill, and cheaper for you.
Cheers
Old 20th February 2003, 11:39 AM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
how do you think most of us got started anyway -- my first ham transmitter used the 6DQ6 sweep tube -- directly keyed. I used the tuner for VHF reception with a slight mod, and oh those power transformers, particularly from early color TV's -- you could get hundreds and hundreds of watts out of them.
used test equipment also makes for great parts supplies -- and the chasis and cabinets just can't be beat. I have one instrument in which I just gutted the entire thing and used a piece of black formica to replace the front panel.
they are still "giving away" old routers and telco equipment due to the glut in networking and telco -- these are excellent rack panel sources.
Old 20th February 2003, 12:34 PM   #4
Christer is offline Christer  Sweden
Some companies even sell industy surplus PCBs for price that
is a fraction of the component value, although this seems less
common nowadays than it used to.
As Jack said, desoldering componentes from old stuff is the way
many of got our first components. Keep in mind, however, that
some components, eg. electrolytics, age and might not be in
good shape. Also take care that some old or odd equipment
might be hazardous to work with. Old residual solder flux might
be more toxic than modern ones. Some equipment may use
transistors or insulators that contain Beryllium oxide etc.
Old 20th February 2003, 02:12 PM   #5
Jeff R is offline Jeff R  United States
Ham fests and flea markets are a great way to get parts, though you might have to go through a lot of items to find what you need. Sometimes at these places you can find bags of unused parts that are perfectly fine.
As Christer says, older electrolytic capacitors might not be worth salvaging, but they still might be worth a try due to the cost of new ones.
Old 20th February 2003, 03:19 PM   #6
JBL is offline JBL  Canada
JBL's Avatar
Send a message via ICQ to JBL
This is also the best way to get cheap transformers for nearly nothing.
Jonathan Blanchard (J.Bl.)
---Nothing is impossible---
Old 20th February 2003, 08:58 PM   #7
With Capacitor you said that some of them might have aged if you test them and there allright can you use them or do they deteriorate in the circuit.
The toxicity isn,t a big problem since i will be doing all the desoldering outside.(it is easer to bring my soldering iron outside to take a few parts and leave the rest than to take it inside and upthe stairs, take the parts of and have to carry it back down the stairs
Old 20th February 2003, 09:04 PM   #8
EchoWars is offline EchoWars  United States
EchoWars's Avatar
With an ESR Tester you may be able to determine the health of older caps, but in general if I have a circuit that I care about, I use new electrolytics. Old ones just shouldn't be trusted.
Old 21st February 2003, 07:40 AM   #9
DIY_Peter is offline DIY_Peter  Belgium
I'm looking for speaker crossover parts. In which devices I'm I likely to find them? caps, inductors, resistors...
please don't answer "in old speakers"
Old 21st February 2003, 12:32 PM   #10
I think I will stick with what you said about capaitors and buy new one they are Quite cheap so it is probably the best way of doing it since the ESR meter would pay for a hell of a lot of capacitors.
Are ther any makes of resistors, transformers, transistors to be wary of and are ther any to look out for.
Pressumembly if the equitment is fairly new you can use the capacitors if they are electroliytic.
Recycling Parts is it possibleHide this!Advertise here!
Recycling old Capacitors keantoken Parts 0 21st April 2008 07:19 AM
Recycling Quad 405 PSU Cap cases Chris Daly Solid State 0 13th April 2008 01:20 AM
Recycling Bozak drivers Ray Collins Multi-Way 0 7th April 2007 12:01 AM
Power supply recycling paulspencer Everything Else 3 11th January 2005 08:57 AM
Recycling parts DIY_Peter Solid State 16 20th May 2003 02:11 PM
Copyright ©1999-2017 diyAudio
