Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st February 2003, 12:53 PM   #11
If you are building something that you plan to use for many
years, you should make sure to buy fresh electrolytics. However,
it can be useful to have a bunch of recycled ones for test
purposes and prototypes. If you build a prototype of something
you do'nt know if you are going to use, or you don't know
what value you need, it might be useful to start with some
old lytics. Then, if it works well with these, you buy appropriate
new ones for the sharp version. If it doesn't work well, you must
of course keep in mind that it may be because of bad lytics.
You may also wish to check this thread on formating old
electrolytics
Which caps to use??
Old 21st February 2003, 06:21 PM   #12
Jeff R is offline Jeff R  United States
My Leach amp still is using electrolytics that I got back in 1979. So, old electrolytics can still be quite good. However, some types that have not been powered up for a long time should be brought up gradually to help the dielectric reform. In other words, don't immediately apply 60 volts to a 75 volt capacitor. Use a variable power supply to slowly bring up the voltage. Someone might know the proper way, but I would suggest maybe applying the voltage in a series of 10 volts steps, with several minutes at each step, possible longer at intermediate voltages.
Old 22nd February 2003, 06:49 PM   #13
TomJ is offline TomJ  United Kingdom
How do you find out the spec's for a transformer if it doesn't have any thing written on it. Is there any way to test for this.
Old 22nd February 2003, 08:32 PM   #14
Weight is generally proportional to the power rating. I don't have a formula, though.
you can use an ohmmeter to find out how the windings were wound. With that figured out, apply some AC to one set of windings (from a sine wave generator - don't plug it into the wall), and by measuring voltages on the other windings you can figure out the turns ratios. You can also look at the wire sizes to get an idea of how much current each winding was designed to handle.
Recycling old Capacitors keantoken Parts 0 21st April 2008 07:19 AM
Recycling Quad 405 PSU Cap cases Chris Daly Solid State 0 13th April 2008 01:20 AM
Recycling Bozak drivers Ray Collins Multi-Way 0 7th April 2007 12:01 AM
Power supply recycling paulspencer Everything Else 3 11th January 2005 08:57 AM
Recycling parts DIY_Peter Solid State 16 20th May 2003 02:11 PM
Page generated in 0.09449 seconds (67.91% PHP - 32.09% MySQL) with 10 queries
