Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th February 2008, 04:18 AM   #11
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
There is always the possibility I drew something wrong, but I'm pretty sure it's true to the p2p wiring. The PNP is pulled down, but it's through the 470ohm resistor. Not sure if a value that low is doing anything. With 20v applied the the output of the bridge, the circuit just sits there. When I put voltage to TP4, I got less than a volt on what I guess is the output. That was with 3A drive current at about 1.5v, the max I of my bench supply. However when I disconnected DC at the bridge, the output voltage stayed there. So what I thnk is the control voltage is appearing at the output, which led me the think maybe the first two stages are for regulation. It seems like the 10W 68v zener does something. Strange one indeed.
Old 19th March 2008, 03:55 AM   #12
Proud Union Member
imix500's Avatar
So I finally got the circuit Conrad posted built. I'm using a OPA703 and a 2.5v reference for control voltage and it works great.
I'm building two versions. One to do loads up to 600W and one to handle around 2kW. The OPA703 has no problem driving 6 medium power mosfets in the smaller load. However, the large 300A darlington modules I'm using for the big load appear to be a challenge to drive. I burned out two OPA703's while testing them.
Would it be easier to find a beefer single supply opamp or should I build a small current stage to drive the big darlington modules?
Thanks!
Old 19th March 2008, 05:36 AM   #13
Wow, that's a big sink. Not sure how many beefy single supply op-amps there are around, so I'd probably go with some kind of transistor buffer. First, I might stick a small resistor in series and make some measurements across it, to try to find out just what the inputs look like so I'd have a better idea of what to build.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 20th March 2008, 03:05 AM   #14
Proud Union Member
imix500's Avatar
Default Toasty OPA703's
So, I built a simple buffer in front of the large darlington module. I worked on it until I blew up the rest of my stock of OPA703's. Can you take a look and see if theres a good reason it's blowing opamps like they insulted it's mother? I think I heard ringing, so oscillation is already on the mind. Thanks!
Old 20th March 2008, 03:30 AM   #15
Fast guess is the loop is too slow. I'd try a small cap, say 100pF from pins 2 to 6 on the op-amp, providing some local feedback stabilization. I'm still not sure why the op-amp would fail, though I haven't looked at the data sheet. Check the common mode and voltage limits for the inputs, and install diodes from the feedback input to ground, the supply, or whatever you need to, to prevent exceeding the voltage range of the inputs. You can also add some current limiting resistance to that input. Some op-amps can go to the supply rails regardless, whereas some have surprisingly narrow limits. Usually no problem when the feedback is working, but kaboom if it oscillates or otherwise loses control.
Old 20th March 2008, 04:02 AM   #16
Proud Union Member
imix500's Avatar
Good points. I noticed it didn't like it when the source connection was broken while testing with the smaller mosfets. Opamp supply current shot up if the transistor was left connected and the load voltage was removed, thought that was weird too.
I agree the issue is bound to be in the feedback loop. This one can take input V right up to supply rails. The V+ input is ok as the highest it will see is 2.5v, but I haven't monitored the V- in to see if it's being slammed somehow. My other thought is maybe there isn't enough feedback, but thats really just a guess.
I'll order some protection parts with some more 703's. Until then, this project moves to the back of the bench. Thanks!
Old 20th March 2008, 05:36 AM   #17
Checked out the data sheet and it seems like a very well behaved part. If you look at the current vs cm voltage, it shoots up rapidly beyond about 5V. They don't continue the curve, but putting a limit resistor on the input still seems wise. Also, the component values were chosen to drive the gate of a MOSFET, so adding the bipolar stage will require modifying those values to get enough drive- that R1 is probably too high.
Old 20th March 2008, 12:54 PM   #18
Proud Union Member
imix500's Avatar
Hi Conrad, on the smaller mosfets it was extremely well behaved. R1 was added because the bipolar stage seems to be very sensitive. With the output idling at ~.1v it was slamming the gate of the large module and the PNP was really heating up. I wonder, with such a large R1 would the feedback loop become unstable?
Old 20th March 2008, 01:25 PM   #19
I know what I'm thinking, but doing a really bad job explaining it! It's not really cm that's an issue, so far as toasting op-amps. I've seen many parts, particularly single supply parts, where, if you get too large a *differential* between the inputs, the current consumption goes way up. Some manufacturers mention this, others don't say a word. They assume you're building an amplifier, not a comparator. Unfortunately, if it oscillates differential voltages are to be expected. As for stability, that bipolar stage raises the gain by a lot. Can you do a G=1 follower? BTW, that NPN is dragging lots of current through the PNP gate. You need a limit resistor!!!
Old 20th March 2008, 07:54 PM   #20
KSTR is offline KSTR  Germany
KSTR's Avatar
FYI, Linear Technologies AppNote 104 shows a known good VCCS, which might be rescaled to drive a bigger MOSFET module. As can be seen, some tweaking with the feedback loop is requiered to get good results (that is, a stable circuit).
- Klaus
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 03:50 PM
troubleshoot: how do I spec a resistor to test as proxy load? riotubes Digital Line Level 0 27th March 2009 04:14 PM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 09:47 PM
How 2 build a Dynamic Load tester? Zero Cool Solid State 2 20th September 2004 06:00 PM
Page generated in 0.12604 seconds (83.92% PHP - 16.08% MySQL) with 11 queries
