| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Ok get yourself some schottyky`s they said.... There are only 500 different ones!
I`m building a 5 and 9 volt supply for a cd player, using 9v toroids, and a 15v toroid. The maximum current will not exeed 2A What schottky`s should do the trick? Are there things I should look in to, like ...? And another question; for the lm317, I have to use resistors, to get to 5 and 9 volt. I`m thinking of using tantaan resistors (is that in english tantal?) does that have ANY bennifits, over using other (metal film?) resistors? The ordering of some components, gives me a headache! tnx in advance guys.
"I`m not the messiah!" |
#2 |
tantalum resistor are fragile and are not recommended becaus of that.
Jonathan Blanchard (J.Bl.) ---Nothing is impossible--- |
#3 |
But do they have any bennifits over other resistors?
#4 |
Probably not, I really don't see what could be better in a tantalum resistor.
Using good quality metal film resistor is enough. (IMO they could be worst than standard resistor but this is just my opinion)
#5 |
And the schottky diodes... Which ones should ik use? I have no idea what to look for.
#6 |
Banned
I use MBR10100.
you could look here: http://parametric.fairchildsemi.com/ss.asp?FAM=Schottky f.e.: http://parametric.fairchildsemi.com/...84,14534,14569 |
#7 |
I use a lot of 1N5822's. They are 3A, 40 volt devices which should be readily available. At 1 A the voltage drop is about .4 volts. I have never had any troubles with them.
I think metal film resistors will be quite adequate. No need to go overboard with an op amp circuit. |
| Bad Schottky?? | pjanda1 | Tubes / Valves | 11 | 27th January 2009 01:21 AM |
| Schottky & Co. | Calamaro | Solid State | 7 | 24th August 2008 07:53 AM |
| what schottky have been used? | freakyone | Pass Labs | 35 | 27th June 2006 01:08 AM |
| SiC Schottky rectifiers. | TugaTweaker | Tubes / Valves | 14 | 29th June 2005 08:57 AM |
| Page generated in 0.09453 seconds (75.90% PHP - 24.10% MySQL) with 10 queries |
