Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th February 2003, 07:42 AM   #1
Default probably another capacitor question.
as with any search for info on caps on this forum, well, is there a post not involving caps? possibly...
anyway, i am a college student in the US, and am trying to blow my tax refund. I have just started with all of this. i made a test circut for a crossover and got some ossilation at 100MHZ as well as really bad results... in fact the results were REALLY bad.
I have decided the fully built unit will likey require bypass capacitors...
i found some 10uF electrolytic caps pretty cheap, like 0.05 each.
the 0.01uF ceramic caps are 0.10 each. while that does't seem like much, the cap bypassing will soon cost as much as the op amps... so will monolithic caps work? they are much cheaper at like 0.03 each. also, the high voltage mylar caps are 0.10. not sure which is better.
also, the input buffer has a 1uF cap listed. i found:
1µF 63V Metallized Polyester Film Cap
and
1uF 100V High Voltage Mylar Cap
no mention of tolerance. i will test the caps and use whichever are closest matches.
any preferance? both are 0.20 each, which is fine because i don't need many.
i know the prices look trivial, but this stuff adds up fast!
if only it could be used for good, not evil...
Old 18th February 2003, 10:41 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Geez! How many rooms did you fill with op-amps!? I can't imagine how anyone could spend more than $10 on ceramic bypass caps...
Tim
Old 22nd February 2003, 02:08 AM   #3
yeah, but i read you should use both electrlytic and ceramic caps, so i get $0.30 per dual opamp that cost $0.50.
Old 22nd February 2003, 03:59 AM   #4
Sch3mat1c's Avatar
I may not be into SS, but AFAIK all you need is a little cap (.1uF ceramic for instance) to keep the chip stable.
After all, the wires leading to the chip will probably have less inductance than the electrolytic, so might as well keep that much at the main supply filter (or group them together at the PSU header on the board or whatever).
Tim
PSU Capacitor question Cloth Ears Chip Amps 11 17th January 2010 12:56 PM
Capacitor Question... SigloOne Tubes / Valves 15 3rd May 2009 07:39 PM
Capacitor question... Again and again... Dxvideo Chip Amps 14 9th January 2008 09:27 AM
capacitor question crippledchicken Solid State 3 31st October 2007 10:12 PM
Capacitor Question audiodumb Car Audio 15 22nd June 2005 04:49 PM
Page generated in 0.08898 seconds (72.62% PHP - 27.38% MySQL) with 10 queries
