| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#2 |
Disconnect pot "RV2"
Connect the two 8K resistors to the negative input of an op-amp. Connect pot "RV2" to the output of this op-amp. (I didn't check the filter values)
Kevin |
#3 |
Kevin is almost right using the inverting opamp as the adder with the two 8k1 feeding the virtual earth. Now, instead of using the 20k pot after the adder, which will alter the source impedance of the following stage, take the output pot back to the virtual earth and use it as a variable gain/attenuation feedback resistor. This maintains a low output impedance which the next filter stage needs to maintain the Linkwitz Reilly crossover slopes. I would change to a 10k pot between output and inverting input to reduce the gain in the bass filter route, or increase the 8k1 to 16k or even 20k. The bass speaker must be connected out of phase with the trebles to correct for the inverting stage of the adding/summing opamp.
regards Andrew T. |
#4 |
I'm not sure that I like the idea of a volume/level control (with long leads) inside the feedback loop. I try to keep the feedback circuit as physically small as possible.
Kevin |
#5 |
simpler solution:
move the LF pot&buffer to the output of either of the low pass filter section outputs split the lowpass filter's 1st section input 7.5K into two 15K, one to each of L/R buffered inputs - replacing/eliminating the 8K resistors as for the design of such a crossover I'd look at Linkwitz' site: http://www.linkwitzlab.com/Pluto/subwoofer.htm shows an example of crossing over to a sub (actually 2 subs), with eq of the sub response |
#6 | ||
Pin6 (output) to pin2 (inverting input) is just 8mm and the pot is similar in size. Standard inverting opamp with variable gain. pot=20k & R1=8k1, gain =+7.8db pot=10k & R1=8k1, gain =+1.8db pot=1k0 & R1=8k1, gain=-18db
regards Andrew T. |
#7 |
All good points so far, but the most important thing I would like to point out is that this crossover is merely a small part of the overall speaker package, and cabinet design and driver specs will have much more of an effect than circuit tweaks.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#8 |
#9 |
I'm confused. Not a rare event. But, if this is for a summed central subwoofer, it seems like level controls on the L and R are not what you need. They can come through as is (unless the gain is high), whereas it's the sub that needs the level control. I built one very similar to this, with one level control on the front panel, and it worked great.
edit- I'd also bring up that it's easiest to get good sound if your satellites are *not* ported, lest there be odd phase problems around the crossover point. IMO, if they're ported it's a good idea to experiment with stuffing the port. I just picked up a small pair of KEF "Q" speakers for the TV, and they actually come with foam plugs, but little explanation. My guess is when one adds a subwoofer, they'll come in handy. |
#10 |
AndrewT say:
pot=20k & R1=8k1, gain =+7.8db pot=10k & R1=8k1, gain =+1.8db pot=1k0 & R1=8k1, gain=-18db It is this formula which you use to obtain these results? Vs = - (R2 / R1) x Ve Which value give to the tension of Ve entry? |
| Active 3-ways with solen active loudspeaker module | soundemon | Multi-Way | 14 | 19th March 2009 11:17 AM |
| for sale four ways active crossover | patriz | Swap Meet | 1 | 6th May 2008 12:42 PM |
| I need a two ways Bessel active crossover schematic | gaetan8888 | Multi-Way | 2 | 30th August 2007 12:21 PM |
| active 2 ways with SPH-165KEP and Fountek neocd 3.0 | Nemophyle | Multi-Way | 4 | 26th July 2005 09:29 AM |
| Page generated in 0.11194 seconds (82.16% PHP - 17.84% MySQL) with 10 queries |
