Active filter 2 ways, your opinions? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st December 2007, 08:00 PM   #11
Here satelites :
http://www.jamo.com/Default.aspx?ID=...roductID=17639
and the boomer:
I want to build a system triphonic.
Old 1st December 2007, 08:06 PM   #12
Speedskater's Avatar
On second look, the RV2 pots may be redundant if the source unit has a volume control. I still don't like pots in the feed-back loop. Hard to get the high frequency compensation right at both extremes of the pot.
Kevin
Old 1st December 2007, 10:02 PM   #13
How to make then? You can modify my diagram?
Old 2nd December 2007, 08:05 AM   #14
Gain=20*log(r2/r1)
if r2<r1 then result is negative.
To avoid Kevin's worry of parasitic capacitance on the inverting input, you can replace the pot with a fixed resistor once you have the levels matched. But, look at any inverting attenuator and they adopt a wide range of adjusting resistors.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd December 2007, 03:07 PM   #15
After clacul here the final diagram. I will use a potentiometer to be welded onto C.I for the RV2.
Does that seem to you corect?
Old 2nd December 2007, 03:53 PM   #16
I think RV2 is too big.
47k/10k gives +13.4db.
each output is mono when the signal is low frequency so the effective gain from adding both channels is 6db higher i.e. +19.4db.
or 47k/(10k/2)=+19.4db
Reduce the pot to 20k (+12db) or maybe as low as 10k (+6db).
0.47uF for DC blocking caps is too low. It will remove some of the sub-bass signal that your summed channel is trying to pass.
2u2F would better suit the 50k input pot.
regards Andrew T.
Old 2nd December 2007, 05:30 PM   #17
Like this?
These new values give a beach of adjustments of +6db to -20db.
The speaker JAMO make 86db output and the sub-woofer make 87db.
According to my style of listening I will be able to adapt the level of the boomer by raport to the JAMO speakers.
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
for sale four ways active crossover patriz Swap Meet 1 6th May 2008 12:42 PM
I need a two ways Bessel active crossover schematic gaetan8888 Multi-Way 2 30th August 2007 12:21 PM
active 2 ways with SPH-165KEP and Fountek neocd 3.0 Nemophyle Multi-Way 4 26th July 2005 09:29 AM
Copyright 1999-2017 diyAudio
