Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 29th November 2007, 09:36 PM   #1
zino13 is offline zino13
Default Magnavox 8002 Amp
Greetings to you All
Kinda new the board and lacking in the tube circuits
but I'm going to learn
I'm doing a rebuild/ mod on a magnavox cosole pull.
It has the....... 2- 6EU7 input/phase inverter tubes,
4- 6V6GT output tubes
1 6CA4 rectifier tube
The pic shows EL84/6BQ5 tubes but the circuit is the same for the 6V6's outputs
Doing replacement with new .01uf 630V poly film caps:
10uf 100v mylar capacitors:
3.3uf 200v polypropylene capacitors
41L .15uf 850v poly caps
Series 40L 10uf 400v poly caps:
I'd like to beef up the power transformer how large can I go?
what kind voltage wise
and Where could I purchase?
ThanX
Old 29th November 2007, 09:57 PM   #2
gofar99 is offline gofar99
Hi Zino13, What voltages do you actually have now? Is the 335 correct? With a 6V6 you might not be able to get much more output as you will run into to max dissipation issues. It looks like you are in the 10 watt dissipation range now and the limits on most new 6V6s are around 14. Older tubes depending on brand are less. A new JJ 6V6 can go to 500 volts max, but you may lose out on the current handling. Should your output transformers be capable, you might consider an upgrade to 6L6s. With the higher voltage they can deliver substantially more output. I won't go into the different sound quality of the various tube types, but there are differences. IMHO, I wouldn't change it. The gains would be unlikely to be significant. Even if you doubled the output power, the sould level increase would hardly be noticed.
Just my 2 cents
Others please feel free to comment / disagree
Old 29th November 2007, 09:59 PM   #3
Just a follow on thought, this would probably be better under the tube amp section.
Thread Tools
B&O 8002 parts? pfcs49 Analogue Source 4 14th August 2008 03:54 AM
B&O 8002 turntable pfcs49 Analogue Source 10 10th December 2007 05:31 PM
B&W 8002 turntable pfcs49 Analogue Source 0 10th November 2007 11:06 PM
Looking for a Hami 8002 Killdrith Swap Meet 0 9th March 2006 08:36 AM
Page generated in 0.17323899 seconds (65.94% PHP - 34.06% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
