Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Capacitors get hot?
Capacitors get hot?
Old 29th November 2007, 02:29 AM   #1
CBRworm is offline CBRworm  United States
Default Capacitors get hot?
I am sure this is a stupid question, but nevertheless:
I have an amp that the original 470uf 80v caps were bulging. there were two of them, I replaced them both with new Panasonic 470uf 80v TS-HA 'large can' caps. They are similarly sized to the originals.
They sit just after a full wave bridge and I noticed that one of them gets warm.
The measured voltage is +80 at one cap and -80 at the other. The polarity is correct and the output is fairly smooth.
In retrospect I probably should have gotten 100v caps, but the last set of 80's lasted many years.
Is it normal for caps to get warm during operation? The rectifier is cooler than the caps.
Old 29th November 2007, 02:41 AM   #2
spock is offline spock  Canada
It's probably not a big deal for caps to be warm, but I always use components rated @ 1.5 x or more rated voltage/amperage.
Old 29th November 2007, 02:44 AM   #3
Magura is offline Magura  Denmark
Magura's Avatar
It is actually a big deal for caps to be warm, as it decreases their expected lifespan considerably. As I recall, it's something like 50% per 10C.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 29th November 2007, 03:47 AM   #4
Boris_The_Blade is offline Boris_The_Blade  United States
Boris_The_Blade's Avatar
is there any thing directly connected to it or in electrical contact with the tabs that gets warm? If no, you will probly wanna up the voltage rating. The leakage current at 80V is high enough to make it warm. If your meter says 80VDC, there is probly a ripple voltage component that exceeds the 80V rating. One other thing..is the amp running at high power when you are checking the cap temperature? If they only get warm then, then the ESR is high enough to be causing the temp to rise because of ripple current. Like magura said, lifespan goes down significantly with slight increases in temperature. Best to increase voltage rating anyway.
Old 29th November 2007, 07:20 AM   #5
t_blizzard is offline t_blizzard  United States
t_blizzard's Avatar
If your original capacitors were bulging there is most likely a problem with the original power supply circuit.
Old electrolytic caps typically dry out but do not bulge.
Bulging is caused by overheating the electrolyte which causes gas vapors to rise out of the vents in the tops of the caps.
Another possibility is that 80V could be too close to their actual operating level and 100V caps should be used in their place.
Old 29th November 2007, 10:38 AM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
Well the heat is a direct offspring of the series resistance of the cap and the amount of current passing through it, a la ohm's law...
2 solutions, find lower ESR caps..... or find caps with higher ripple current handleing...
A higher voltage cap, normally has lower series resistance, so that is starting to think in the right direction....
Old 29th November 2007, 12:06 PM   #7
I think I will go ahead and get some higher voltage, low ESR caps.
The heat is mostly generated at idle. As for the power supply circuitry, it is so simple I can't imagine there is anything wrong. This particular piece is connected directly to the output side of a diode rectifier which is connected directly to the output of a transformer. This particular piece of the supply is low current capable of sourcing only 2 amps.
Old 29th November 2007, 02:38 PM   #8
Conrad Hoffman is offline Conrad Hoffman  United States
Though rare, a leaky rectifier diode will do it. If they're easy, I'd change 'em out with the caps.
Old 29th November 2007, 02:57 PM   #9
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Capacitors get hot?
How much is "warm". Do they selfheat or do you have a warm environment?
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 29th November 2007, 03:09 PM   #10
I think it is a combination of voltage right up at the cap limit and lack of ripple current rating.
If the supply already shows 80Vdc across the caps, then when mains voltage rises it is going to be even worse.
You really do want your caps to run cold if possible.
regards Andrew T.
Sent from my desktop computer using a keyboard
Capacitors get hot?Hide this!Advertise here!
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 12:38 PM
Continental Capacitors' "Type-A" oil-filled capacitors? radical Parts 0 21st October 2004 08:39 PM
Oil capacitors Praudio Swap Meet 3 7th October 2003 03:00 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 09:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 01:29 AM
Copyright ©1999-2017 diyAudio
