Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th February 2003, 05:17 AM   #1
colin.hepburn2's Avatar
Default Help advice on good sondind cheper resistors
Hi can someone advice me on some good sounding cheaper resistors for cascade single ended audio Amp I was using Holco but stocks are thin And cost is high here in the UK.
Olso require some help with output Trans replacements for 2N3716}{2N3792}
Cheers
Colin
The Blues Man
Old 17th February 2003, 06:32 AM   #2
EchoWars's Avatar
I've been using Yageo metal film resistors for quite some time with good success.
Old 17th February 2003, 06:42 AM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Beyschlag resistors are supposed to be not bad, also Roederstein.
How good are Beyschlag resistors from Digi-Key?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 17th February 2003, 11:05 AM   #4
fezz is offline fezz  United Kingdom
im not sure how cheap you mean, but Rapid eletronics in the UK (01206 751166) sell Meggitt Holsworthy precision (0.1%) resistors at very good prices:
10R-47R - £6.50 for 5 £43.00 for 50
56R-82R - £4.50 for 5 £27.50 for 50
100R - 270K - £3.00 for 5 £22.00 for 50
330k-1M - £6.50 for 5 £43.00 for 50
Old 18th February 2003, 09:16 PM   #5
Default Resistors
Hi Jezz
Thank you, for the info on the resistors I had forgotten about Raped Have order catalogue from them still have not found my TO3 Darlington Trans 2N3792, 2N3716 though I have been told I can use MJE 15003 ,15004 in place of the above
Thanks again
Colin
Colin
The Blues Man
Old 21st September 2007, 08:23 PM   #6
HBrunt is offline HBrunt  United Kingdom
I've just found two pairs of unused Texas Instruments 2N3716 2N3792 in my parts box (lurking at the bottom). I reckon they must be over 30 years old as I have had that box since I was about 8 or 9. Are they good for anything?
Old 23rd September 2007, 07:01 PM   #7
buy 600mW metal film (mrs25) from rapid in 100 quantity and the price is about £2.20
These sound good if you keep the dissipation down, preferably below 10% but even upto 50% is OK.
I think the cheaper mf60 are just about as good.
regards Andrew T.
Good sounding 6V6 PP UL driver circuit? SHiFTY Tubes / Valves 20 30th April 2007 12:34 PM
Good/Bad Sounding Chips Wynand Chip Amps 12 15th July 2005 05:36 PM
Cheaper, good quality potentiometers paulb Solid State 30 25th February 2004 03:30 PM
What are "good" sounding resistors for my aleph p Shaun Perez Pass Labs 6 29th July 2003 02:46 PM
Page generated in 0.10587 seconds (73.03% PHP - 26.97% MySQL) with 10 queries
