Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd November 2007, 10:22 PM   #1
yamfox is offline yamfox  United States
Exclamation Connect TV to Aux??
Hi, i'm new, and I would like to connect my TV to my Bose WaveRadio through the aux but my tv doesn't have a headphone jack to put an Aux cord in. I was wondering the cheapest possible way to get around this.
Thanks,
YAMFOx
Old 22nd November 2007, 10:26 PM   #2
leadbelly's Avatar
Buy yourself a cable with a headphone plug at one end and 2 RCA plugs at the other end.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 22nd November 2007, 10:31 PM   #3
pinkmouse's Avatar
Most importantly, do not attempt to take the TV apart to make connections internally. CRTs use very high voltages and are highly dangerous, even qualified service engineers need specialist tools and lots of experience to work on them safely. Because of this, we do not allow posts that encourage this practice on diyAudio.
If your TV has no headphone out jack, then your only other possible alternative is if it has a Scart conector on the back, these sometimes have audio out connections. If it has, you would need to google the pinouts, and make up an adaptor lead. If not, you're out of luck I'm afraid.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 22nd November 2007, 11:02 PM   #4
Not all TVs even have line isolation transformers, and you really don't want to mess around with that. If the TV is transformer isolated, there can still be big hum problems with user installed jacks; that then has to be fixed with an audio isolation transformer, so as pinkmouse says, if it hasn't got a jack already, it isn't worth your life to install one.
Old 22nd November 2007, 11:54 PM   #5
theAnonymous1's Avatar
Are you sure the TV doesn't already sound better than the Bose?
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 23rd November 2007, 12:26 AM   #6
run the tv signal thu a vcr 98% of vcr's have audio out....
Old 27th November 2007, 01:54 AM   #7
dangus is offline dangus  Canada
If your TV doesn't have RCA audio outputs, just check on the local Craigslist and get yourself a better TV. People who've bought flat-panel displays are practically giving away some very decent 27" to 36" CRT sets.
You can also check around for cable box converters with audio outs, since those will generally offer remote volume and mute.
How connect the Gnd. samsagaz Chip Amps 50 19th May 2008 05:09 AM
How to connect a sub??? Klimon Subwoofers 6 19th June 2006 03:18 PM
connect a sub to amp JSD777 Chip Amps 8 26th October 2005 04:16 PM
best way to connect this amp.. jonz Solid State 2 18th May 2004 06:54 AM
Best way to connect a sub to a GC? sounder Chip Amps 5 13th October 2003 04:40 AM
Page generated in 0.07902 seconds (76.48% PHP - 23.52% MySQL) with 10 queries
