Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd November 2007, 03:36 PM   #1
Default Converting watt to VA???
Hello,
I have an 110V preamplifier/processor that I am using in the UK. For the moment I am using an external converter but I just noticed that I have a lot of space inside the chassis so maybe I could put a step down transformer in there instead. I still want to keep the original transformers because there are so many conversion inside the unit (for 5V, 30V and something else I don't know what it is for) so the easiest option would be to just step everything down to 110V. Bassically I am just moving the step down inside the chassis.
I know the preamp uses 50 watt, what VA should I choose for the step down transformer? I m thinking if an isolation transformer like this, should it work (is available from 50VA to 500VA):
http://uk.farnell.com/jsp/Electrical...sp?sku=9938443
Thanks!!!
Robert
Old 22nd November 2007, 04:13 PM   #2
you could use 50VA for 50W of consumption.
But running a transformer at full power all the time creates quite a lot of heat.
Usually VA takes account of phase angle of the load, but this is generally ignored by us audio lot.
Instead adopt the de-rating specified by the transformer manufacturers when using a capacitor input filter after the rectifier.
De-rate the transformer to 70% for power output. Since the rectrifier and smoothing will increase the DC output voltage by a factor of sqrt(2) the continuous output DC current becomes half of the rated AC current.
If you need +-25V @ 1A you need 50/0.7=70VA @18+18Vac. A 70VA 18+18Vac transformer is rated @ 1.9Aac (about twice the maximum DC current avialable for your circuit).
Does your pre-amp really consume 50W continuous? or is that a worst case condition that is rarely if ever reached?
regards Andrew T.
Old 23rd November 2007, 06:30 AM   #3
Great, thanks for your answer!
I got the power consumtion from the back of the unit so I guess it is the maximum.
So if I go for a 100VA I should be safe? I could fit a 160VA as well, and the price and size difference is not that big. Any suggestions/thoughts?
Thanksfor your time!
Robert
Old 23rd November 2007, 07:02 AM   #4
By the way, I guess this transformer is single phase (no center tap), does that mean anything for a standard step down conversion?
It is also an isolation transformer, is that good?
Or should I use something like this (toroidal w 2*55V secondaries, running in series)?
http://uk.farnell.com/jsp/Electrical...sp?sku=9532765
Sorry for all these questions, but I really want to make this work as good as possible!
Robert
Old 23rd November 2007, 09:05 AM   #5
I like toroids, many others don't, particularly for lower power needs.
The EI seems to let less garbage through from the mains and this helps pre-amps to perform better.
If your maximum input power is 50W then a 50VA EI could be the way to go.
Your selected isolator could be a very high quality unit, but it omits to mention regulation and electrostatic screening. Hard to decide if this unit is worth the extra cash.
I did see another poster use a 240/440Vac isolation transformer that weighed about double the normal for it's rating and regulation was exemplary for an EI, even bettering toroids in this respect. I cannot recall who the manufacturer was, but RS or Farnell was the retailer.
Could you measure the power consumption of your pre-amp? It could be as little as 10W!
regards Andrew T.
Old 23rd November 2007, 01:02 PM   #6
Thanks again for your answer, really good stuff and I am actually learning something
I can't really measure the wattage of the unit, but I agree that 50 watt seems like a lot (although it is a processor preamp).
http://www.outlawaudio.com/products/990.html
I would really like to try the isolator, do you think it is a too big risk and that I should just grab the toroidal?
I just hate choices that I don't know everything behind, please make the decision for me
Robert
Old 29th November 2007, 07:20 AM   #7
t_blizzard's Avatar
The 50VA isolation transformer will work just fine.
Trenton
Old 29th November 2007, 07:58 AM   #8
Bobken is offline Bobken  United Kingdom
I would favour Andrew's suggestion and go for a toroid if you are not already committed to purchasing the more costly isolation transformer.
The stray magnetic fields from a toroid are likely to be much lower than any usual 'EI' type of transformer, which I assume this isolation transformer must be.
You say you intend to install this in the existing enclosure, which clearly has a lot of low-level (and therefore probably sensitive to hum pick-up) circuitry within this enclosure. This being the case, you might end up needing to add some internal screening around the 'EI' type, but this is much less likely with a toroid.
Bob
Old 29th November 2007, 08:18 PM   #9
t_blizzard's Avatar
50VA should work just fine.
Converting TO-220 to TO-247 Clipped Car Audio 5 24th July 2007 06:59 PM
Converting a DAC harrygrey382 Digital Source 48 15th June 2007 09:16 PM
Converting a DAC-in-the-Box to I-out? Aleksunder Digital Source 0 26th May 2007 11:44 AM
Converting a DCC into a DAC harrygrey382 Digital Source 0 21st May 2007 10:10 AM
Converting Bl ht_boy Multi-Way 2 12th December 2005 04:32 AM
Page generated in 0.11068 seconds (78.16% PHP - 21.84% MySQL) with 10 queries
