| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I see a datesheet of transformer as attach, so small and so big power!
Would you tell me is it a good quality transformer? 487W Diameter=123 High=57 |
#2 |
3.2kg and 487VA seems about right.
primary wire gauge is very small @ 0.33sqmm carrying 6.4A/sqmm. secondary wire gauge is just as bad @ 1.3sqmm carrying 6.1A/sqmm. This transformer is likely to have a fairly high regulation for it's rating and will run a bit hotter than one with more copper. The low voltage secondaries are just about what is expected of current types.
regards Andrew T. |
#3 |
Can I use it for HIFI Machine. Have some trouble?
#4 |
The power rating is so high, because it is related to 73 deg. C rise, which means your transformer will be at ~100 degC.
Reduce current consumption in the secondary, and it will be cooler. |
#5 |
The vendor tell me the Plitron transformer is one of the best over the world. As you comment, it seem to ...
If you give it a grade from 1 to 10. 10 is very good, 1 is very bad. Would you please give your comments? |
| Toroidal transformer for F1 | milezone | Pass Labs | 7 | 24th September 2009 09:23 AM |
| where to buy a toroidal transformer | zafira1981 | Power Supplies | 2 | 13th December 2005 12:46 AM |
| Toroidal transformer more than 2 x 55V | djdamix | Parts | 2 | 20th November 2004 05:04 PM |
| FS: 18-0-18v Toroidal Transformer and More... | Maples | Swap Meet | 12 | 7th August 2004 12:44 PM |
| Toroidal Transformer | sma | Solid State | 3 | 3rd February 2004 07:55 PM |
| Page generated in 0.07934 seconds (72.86% PHP - 27.14% MySQL) with 11 queries |
