Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th February 2003, 02:44 PM   #1
Question Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple
Hi everybody!
What I want to do ist to reduce the current ripple in my 65V-0V-65V (5A-0-5A) PSU.
It is based on:
2x block transformer (230V/46V 320VA)
8x 4700myF/100V electrolytic filter capacitors
2x 700V/35A metall bridge rectifier
4x 10myF MKP capacitors (2 per rail)
and 2 4k7/10W resistors
I use it to power my 2x150W A/B power amplifier.
My question is:
Can I reduce the ripple current by wireing the second transformer antiphase so that the maximum + of the one trafo is at the same time than the max - of the other trafo?
I thought, that this would smooth the ripple at the end of the PSU and give a cleaner voltage for the amp.
Is this right? Please give me your suggestions!
Thanks,
the toasted
Old 16th February 2003, 07:06 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Quite simply, it is impossible, without having the DC cancel as well (i.e. two +65V supplies). Note that would be measuring +65 to +65, not +65 to ground, which would still have the same hum. (Point being, they both have the same hum.)
What is an MKP cap? Anything special? Reference to purpose?
In any case, to remove hum completely (practically so anyway), throw in a choke. 150W isn't small beans, so the chokes (one for each, + and -) will need to be pretty large.
BTW, hold down ALT then on the keypad, type 0181, then release ALT. You get a Greek mu 'µ'. If that's too much bother, at least use a plain 'u' for micro.
Note also that, though many will misunderstand it (go figure), the correct letter for such large values is 'm', thousandths. Thus, 10,000µF = 10mF = .01F.
Tim
Ill be getting wired here now... phluffy Introductions 2 4th May 2009 04:42 PM
is this wired right? shooto Instruments and Amps 1 17th July 2006 03:47 AM
what size amp for DPL 12 wired for 4 ohm? crippledchicken Subwoofers 7 20th January 2005 12:10 AM
Help:How To Reduce Transformer Output Voltage? phill77 Solid State 0 21st April 2003 01:04 PM
Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple the toasted Solid State 6 18th February 2003 03:13 PM
Page generated in 0.07340 seconds (69.56% PHP - 30.44% MySQL) with 10 queries
