Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th February 2003, 04:00 PM   #11
Originally posted by fr0st
This is my first SMPS so i'm still learning the parmeters to quote.
The core 35mm Od, 21mm ID and 13mm high.
I'll just assume it'll work and I'll incorerate a thermal fuse just incase.
If it's 35mm od, it'll probably do 400W (or close to it anyway). I'm guessing that you probably won't need to thermally fuse the transformer, most of your heat will probably come from the power switches (mosfets).
-Dan
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
New Ultrafast Diode Bridge group buy? bigparsnip Group Buys 135 6th March 2006 09:52 PM
IR HFA08TB60 Ultrafast Soft-recovery DIODE canvas Swap Meet 1 21st August 2004 04:47 PM
Page generated in 0.05489 seconds (66.75% PHP - 33.25% MySQL) with 10 queries
