What to look for in a replacement complementary output transistor? What to look for in a replacement complementary output transistor? - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th November 2007, 04:51 PM   #1
spooney is offline spooney  United States
Default What to look for in a replacement complementary output transistor?
I'm doing work on a car audio amp and am having some trouble locating exact replacements for the output transistors. How do I determine if another transistor will work as a replacement?Do I just need to find one with equal or higher maximum ratings?The transistor in question is a KTB688. I have a few 2sa1909 transistors laying around and the ratings appear to be higher.Will this part work in place of the KTB688?Also if it will work will i need the complement to the 2sa1909 or will the complement to the ktb688 work with the 2sa1909?
Old 11th November 2007, 04:54 PM   #2
hi,
the b688 could be short form for 2sb688.
the complement would be 2sdxxx?
or could ktb be a FET which are very popular in car audio?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th November 2007, 05:21 PM   #3
KTB688 and 2SD688 are the same part pretty much with different prefixes.The complement would be the KTD718 or 2SD718
What to look for in a replacement complementary output transistor?Hide this!Advertise here!
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 26 28th April 2016 10:34 PM
quasi-complementary output Vlad Pass Labs 4 13th April 2010 12:07 PM
Complementary Symmetry Output SISKO Tubes / Valves 2 4th September 2007 06:35 AM
CK-KumisaIII amp output transistor replacement? h_a Solid State 3 14th June 2007 04:39 PM
How important is complementary transistor pair matching in class B amp? caesar148 Solid State 10 15th October 2004 07:06 PM
Copyright ©1999-2017 diyAudio
