| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I found a box of the VN0109 lying around at my workplace. They are the metal case type with gold pins. They N channel FET , but can anyone advise what can i do to make good use of them ie. in what applications? Or what other parts can they be cross-referenced to?
http://www.ece.ucsb.edu/Faculty/rodw...37A/VN0104.pdf |
#2 |
from the datasheet:
Applications - Motor controls - Converters - Amplifiers - Switches - Power supply circuits - Drivers (relays, hammers, solenoids, lamps, memories, displays, bipolar transistors, etc.) This mosfet is a low voltage, high drain-source resistance, very low current device.... you can use it in low power application only |
| What makes the good guitar pickup sound so good? | darkfenriz | Instruments and Amps | 15 | 1st March 2009 11:46 PM |
| Good general purpose opamp with good DC specs? | speakerguy79 | Parts | 1 | 17th November 2006 04:10 AM |
| Good switch for Stepped attentuater, Good cheap RCA jacks | pjpoes | Parts | 20 | 10th March 2005 08:47 PM |
| Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? | XteveX | Multi-Way | 7 | 28th April 2004 04:05 AM |
| Page generated in 0.06892 seconds (69.06% PHP - 30.94% MySQL) with 10 queries |
