| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#41 |
I would simply use SMD's directly. I would get SMD soldering tips though. Although soldering SMD's is very easy, desoldering SMD's happened to be pain in the posteriors. I mistakenly modded the EVM so I had to do few desoldering. SMD IC's are whole different matter. I didn't do soldering SMD IC's for my amps, but I did few elsewhere. I remember, being able to solder them on. But I never succeeded in taking them off since I used double-sided tape or glue to hold them in place. What about my amp? Its good ol' non-inverted NFB opamp amp. So I didn't need testing. Besides, it was EVM board. I knew it's gonna work ... So I was CHEATING. (Well, after doing SMD at work, I didn't feel like doing SMD from scratch at home at the time ... It's awhile back.) T |
#42 |
Peranders -
This is ma "cheater" SMD amp for viewing. Why? Primarily to make fun of it. Surprsingly good sounding however. Tomo |
#43 |
Hello,
Underside of the EVM amp board look like this. Tomo |
#44 |
This is close up of the modded EVM board. Notice non-uniform soldering. It is the trace of me soldering. Most of resistors had to be replaced. Tomo |
#45 |
To get back on track...I've used the caps you refer to extensivly and find them pretty good. I think the tinned led foil is more imortant then iron legs.... actually find them sonically (OK marginally) superior the the wima variant...
Cheers |
| Polypropylene caps | liberty | Tubes / Valves | 21 | 31st August 2009 06:04 AM |
| anyone ever used metalized polypropylene caps from Digi-key? | crtubes | Tubes / Valves | 6 | 15th September 2005 11:47 PM |
| 10 uF Polypropylene caps | dsrjohn | Parts | 9 | 5th May 2004 01:30 AM |
| Where to get polypropylene caps with <2,5% tolerance in Norway? | Alcaid | Parts | 5 | 23rd February 2004 08:54 PM |
| Page generated in 0.07720 seconds (75.33% PHP - 24.67% MySQL) with 11 queries |
