| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am building a CNC controller for my mill, i have scrounged up a nice aluminium 2u server which has a lot of extra space to put the interface board, gecko drivers, relays and power supply.
I am planning to keep the small microatx p4 motherboard in there, it has a printer port which i need for the mach3 software. anyways the corner of the motherboard farthest away from the CPU would be quite close (about an inch or 2 ) to the 320VA toroid i am using to drive my servos. would the toroid introduce enough hum into the PCs circuitry to make it unreliable or crash? or should it be ok if i put a shield between them. thanx n7 |
#2 |
If you are Concerned about Hum maybe try a Mumetal Can or Shield for the Toroid to block the Magnetic Field.....
#3 |
Mount the PCB and toroid so that the hole in the toroid is facing the most sensitive parts.
Maximum radiation is in the plane of the toroid if you think of the toroid as a disc. In the 90 degree axis (imagine a line straight thru the hole in the toroid) the radiation cancels almost completely due to the way a magnetic field is radiated from a wire and the way a toroid is winded on the core. /Peter |
#4 |
I cant really do that the case is 2u and the toroid is about 7" in diameter (its a low profile 320VA)
however today i rearranged the computer PSU and the toroid can be about 4" away from the motherboard. ill just put a shield between them and see how it goes. |
| Nice motherboard | DragonMaster | Everything Else | 1 | 4th February 2007 07:02 AM |
| Asus Motherboard | herm | Everything Else | 5 | 3rd January 2007 09:11 AM |
| Trade a 40V 400VA Toroid for 20V 300VA Toroid | john65b | Swap Meet | 7 | 10th October 2006 03:49 AM |
| How big Harddrive can I use with my motherboard? | Christian | Digital Source | 44 | 5th August 2003 07:03 AM |
| New computer motherboard with integrated tube amp | ThingyNess | Everything Else | 17 | 5th June 2002 07:12 PM |
| Page generated in 0.08651 seconds (72.90% PHP - 27.10% MySQL) with 10 queries |
