| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am searching for cups to pot diy toroid chokes. Does anybody know where I can order them? What kind of material should I use to pot the toroids? Any kind of help or hint is welcome. |
#2 |
How large are the cores?
I've heard of people using the caps to aerosol spray-paint cans before,for smaller toroids...And ABS/PVC 'end caps' for larger ones. Some ABS Stuff |
#3 |
Hello,
I have some 8cm cores and some 15cm cores. Thanks for the link. |
#4 |
diyAudio Moderator Emeritus
You could use a coffee or soup can. Emptied out and cleaned of course!
As far as what to use for potting, I'm pretty sure most companies use a 2 part mix. We use something at work that looks very similar to the potting in the center of Plitron toroids and it is a 2 part mix that cures fully in about 24 hours. I believe it is made by Loctite. Alternatively, you could use some kind of epoxy.
Brian |
| Grundig AKTIV-BOX 20/30 - Searching 4 parts | fosforo | Swap Meet | 0 | 19th June 2008 10:12 AM |
| Searching for toroid, 2x70V seccondary... | CJ900RR | Parts | 13 | 7th September 2007 07:41 PM |
| Trade a 40V 400VA Toroid for 20V 300VA Toroid | john65b | Swap Meet | 7 | 10th October 2006 04:49 AM |
| FS: Aleph 3 Power supply parts, caps, toroid and heatsinks | vsr123 | Swap Meet | 4 | 20th March 2005 11:40 PM |
| Searching Digital Audio Parts | mamu | Swap Meet | 3 | 15th January 2005 09:20 AM |
| Page generated in 0.08819 seconds (61.64% PHP - 38.36% MySQL) with 10 queries |
