| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can you recommend a supplier of nice aluminum (preferrably cast) or steel boxes? I checked Hammond and BUD and some others, but the dimentions are not suitable. I want to use it for a PS case, for a gainclone and the inside dimensions have to be at least 4.9 X 6 X 2.75".
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#2 |
I saw this link here a few weeks ago...
(I just hope that this link isn't from one of your post !) Anyway, here it is : Online Metals Check also : Chassis which was found in this forum too ![]() Hope this helps Regards |
#3 |
#4 |
I found this link for those who are interested to have some parts machined but are not equipped to work with metals.
You simply design your parts using a CAD software (there's also a simple software available for download) and then send you drawings using your computer. However, I wonder how much could cost a drilled/holed/chamfered,brushed faceplate ?
#5 | |
<a href="http://www.mouser.com//index.cfm?handler=productsearch._listproductsearch &searchtype=starts+with&criteria=400-4597&searchby=PartNumber&x=13&y=13">http://www.mouser.com//index.cfm?han...mber&x=13&y=13</a> se |
#6 |
Pomona http://www.pomonaelectronics.com/ make a nice range of extruded aluminum boxes. Ideal for PS's
#7 |
I have looked for similar products here too and noticed that it is very hard to find a nice molded box if you have some set dimensions in mind. And with quality finish (Rolec, Boss), they don’t come cheap as well.
Peter, with your skills and tools available, I would look some box shape extrusions. You can cut them to desired length and add end caps. Who knows, you can make some small box supplying service out of that in your spare time. Anyway, here is a little bit different way of using aluminum-molded boxes (ala Hammond).
#8 | ||
#9 |
#10 |
Twice I have bought used audio ( a k7 player and an amp) in a thriftstore
for $2.49 each. I took of the front and emptied the case, then spraypainted the casing's cover. I replaced the original front with a front I made and the result is very satisfying for me. If asked for I can post pics during and after the job. J-P. |
| Philips AD3800 in nice boxes, what are these? | pjanda1 | Full Range | 13 | 5th October 2009 05:56 PM |
| FS - BLH boxes | t-head | Swap Meet | 1 | 23rd October 2008 05:22 AM |
| new boxes | GringoAudio | Multi-Way | 2 | 18th August 2004 04:50 AM |
| 2 boxes | zcab911 | Multi-Way | 2 | 17th July 2003 10:38 AM |
| Subwoofer Boxes!!!!!!!!!!!!!! | jahl | Car Audio | 9 | 7th July 2003 08:31 AM |
| Page generated in 0.12214 seconds (83.32% PHP - 16.68% MySQL) with 10 queries |
