Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
New opamp from National
Old 13th February 2003, 02:39 PM   #1
MRehorst is offline MRehorst
MRehorst's Avatar
Default New opamp from National
LMH6624 - Ultra-low Noise Wideband Op Amp
* 1.5 GHz Gain Bandwidth Product
* 0.92 nV/ rtHz Input Voltage Noise
* Low DC Errors: 100 ÁV V os , ▒0.1 ÁV/░C Drift
* Low Distortion: -65/-80 dBc HD2/HD3 @ 10 MHz
* Applications: high-resolution applications, communications,
xDSL, audio, medical and instrumentation markets.
* Link to Product Folder/Free Samples:
Link
MR
Keeping an open mind since 2002...
Old 13th February 2003, 02:59 PM   #2
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Good tip Mark, thanks.
Jan Didden
Old 13th February 2003, 04:29 PM   #3
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I wonder how this opamp is in the audio perspective? Is it suited (well-suited) for audio or is it better for HF applications?
Many parameters have impressive data but it's not the same thing as good for audio. Notice also that this chip is really small, SOT-23!
Just wondering.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 14 pcb's in interest so far.
Old 13th February 2003, 04:41 PM   #4
fmak is offline fmak
Default Re: New opamp from National
[QUOTE]Originally posted by MRehorst
[B]LMH6624 - Ultra-low Noise Wideband Op Amp
Looks good; pity it's confined to +-6V. Does anyone know how it sounds?
Old 14th February 2003, 12:58 AM   #5
Ilianh is offline Ilianh  Canada
Ilianh's Avatar
Send a message via MSN to Ilianh
Default new opamp
I found this new opamp from national, specs look very promising, anyone ever used it for hifi applications?
http://www.national.com/ds/LM/LMH6624.pdf
Time is the best teacher; unfortunately, it kills all its students
Old 14th February 2003, 01:42 AM   #6
halojoy is offline halojoy  Sweden
On Hiatus
Default Re: new opamp
What is the price?
I guess it costs more than NE5534
It does not come in normal DIL, but in SO8 package.
It is for small signals and has slewrate 300MHz.
Supply voltage is only +- 6V
Etreme dc-offset precision performance.
It is not mainly intended for Audio-band.
But might be useable in some mic/riaa amplifier
as it has only 0.9nV/-Hz. Like AD797.
I will read some more from the PDF.
/halo
Old 14th February 2003, 02:33 AM   #7
Ilianh's Avatar
I wonder about using it with single supply...
and +\- 6v is that bad? I think thats enough for most of the signals we work with..
And opamps of this generation can saturate preety close to the supply rails...
still......
I'll order some samples for fun.
btw, any ideas whats the best opamp made by national, for audio (lm833?)
Old 14th February 2003, 02:44 AM   #8
On Hiatus
still......
It is impossible to say what OPamp is best for audio.
It ALL depends on what sort of audio spplication you deal with.
Some OPamps are good, or at least NOT bad,
in any application.
That makes them popular to have at home. Like 5534/5532.
One OP might be best as Phono-riaa amp
another for low-voltage battery appl.
A third is perfect as the heart/voltage-gain controller in a Power amp
The area of OPamp use in Audio is a BIG field.
So best OPamp choice, will mostly be different depending on what you want to do.
But you will still go a long way with some popular op-amps.
OPA2134 is one. Not really bad on anything.
Generally useful, and with acceptable price.
/halo - still find very good use for NE5534/32
Old 14th February 2003, 03:17 AM   #9
Ilianh's Avatar
I was reffering to national for their samples service, people like me dont have money to pay for stuff
one day when iIget out of school... but for now.. I'm broke
Old 14th February 2003, 11:39 AM   #10
carlmart is offline carlmart  Brazil
Default Specs
The chip certainly deserves a try.
It has impressive gain bandwidth (1.5GHz), slew rate (350v/us) and settling time 15ns.
Voltage swing is +/-4.9v (using a +/-6v supply) and PSRR is about 90dB.
The latter means that it might need a good supply, but looks very promising.
Trying it as a RIAA stage might be interesting, coupled to something like a BUF634/LT1010, like on the LT1115 RIAA application.
They suggest audio applications on the data page, which is already good.
Pity it's a SOIC type only, which limits DIY applications somehow.
Carlos
New opamp from NationalHide this!Advertise here!
National opamp inflation Tolu Solid State 380 14th February 2015 05:25 PM
National Semi opamp seminar pinkmouse Solid State 8 5th November 2007 11:59 AM
National TV davidallancole Solid State 9 8th August 2006 12:25 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
National.com audioPT Everything Else 4 10th September 2002 03:39 PM
Copyright ©1999-2017 diyAudio
