| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
I've had them around for a few weeks now... ...even have a so-8 soldered into a dip converter. I have yet to try it. Specs look good, and it should be fast, but am finding that the limiting factor is the +- rail voltage being so low. Very annoying!
-Dan |
#12 |
On Hiatus
quote:
Originally posted by Ilianh I found this new opamp from national, specs look very promising, anyone ever used it for hifi applications? http://www.national.com/ds/LM/LMH6624.pdf ------------------------------------------------------------------ What is the price? I guess it costs more than NE5534 It does not come in normal DIL, but in SO8 package. It is for small signals and has slewrate 300MHz. Supply voltage is only +- 6V Extreme dc-offset precision performance. It is not mainly intended for Audio-band. But might be useable in some mic/riaa amplifier as it has very low noise, only 0.9nV/-Hz. Like AD797. I will read some more from the PDF. /halo ------------------------------------------------------------------ As there are two threads about the same OP, I now move my answer here, as this one is a bit more active. This was the other - it seems dead already: http://www.diyaudio.com/forums/showt...threadid=11129 /halo - |
#13 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#14 |
Please read the LMH6624 data sheet and look at the
graphs. It's a big mistake to judge an IC by the bulleted list at the top of page one. This low noise figure of 0.92 nV/rt(Hz) is measured at 1MHz. The graphs show the 1/f corner for the noise to be somewhere between 10kHz and 100kHz, depending on whether you are looking at voltage or current noise. So noise in the audio band is SIGNIFICANTLY higher than the 0.92 nV/rt(Hz) number. Note also that noise is particularly difficult to characterize and most people don't do a very good job. So don't really expect it to be as advertised. I would be cautious about trying to use an amp with 1.5GHz GBW for audio applications. This is NOT for the uninitiated or those with weak constitutions.
bel |
#15 |
1.5GHz GBW for audio applications. This is NOT for the uninitiated or those with weak constitutions. [/B][/QUOTE] ---------------------------------------------- I agree although one ahould limit the bandwidth somewhat. I got my samples ulttra quick with a little circuit board!! |
#16 |
Yes, given a manufacturer's demo board you should
be able to build a working circuit. But what about the person who tries to create their own PCB? What about the person who decides to use some big audiophile film caps for bypassing? etc. etc. I think that for most audio applications one would be better off with more "normal" parts.
bel |
| National opamp inflation | Tolu | Solid State | 282 | 25th December 2009 05:10 PM |
| National Semi opamp seminar | pinkmouse | Solid State | 8 | 5th November 2007 11:59 AM |
| National TV | davidallancole | Solid State | 9 | 8th August 2006 12:25 AM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| National.com | audioPT | Everything Else | 4 | 10th September 2002 03:39 PM |
| Page generated in 0.09990 seconds (74.47% PHP - 25.53% MySQL) with 10 queries |
