| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am in the beginning stage of putting together amp6 (t-amp clone). While I was winding the toroid inductor with the 0.5mm copper wire, it broke off. The size is similar to 24 gauge.
I am unable to find a replacement, closest at local craftshop sells 24 gauge copper wire but without the enamel coating as the original amp6 wire. Any experts here? Where can I get a proper replacement?, I assume the enamel coating is a must?. Radioshack has wire but is little too thick at 22 gauge. would like some help. thanks, gychang |
#2 |
diyAudio Moderator Emeritus
Hi gychang.
I have some spare wire I can send you. Just email me your address.
Brian |
#3 | |
gychang |
#4 |
if BWRX had not kindly offered some spare, you must use enamelled copper wire. It is usually sold on 100gm, 500gm or 1kg reels. Generally available from many sources. It is sometimes called magnet wire but best to check what the spec is before buying. In the UK, I use The Scientific Wire Company (SWC).
regards Andrew T. |
#5 | |
thanks, BWRX is helping me out. gychang |
| Winding a Monster Toroid, Hum & Voltage Sag | EWorkshop1708 | Power Supplies | 25 | 28th June 2011 08:26 AM |
| toroid winding robot | star882 | Parts | 1 | 22nd June 2009 04:08 PM |
| Do you think amp6 plus toroid will fit into this case? | fcj | Class D | 3 | 2nd November 2006 08:00 PM |
| winding multiple secondaries on a toroid??? | Puggie | Power Supplies | 3 | 9th August 2006 05:58 PM |
| Repairing Scraped Winding on Toroid | KT | Parts | 1 | 20th July 2004 02:47 PM |
| Page generated in 0.07977 seconds (74.88% PHP - 25.12% MySQL) with 10 queries |
