So far I've found some 6 gang pots on ebay, and they don't state if they are lin or log:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=7571039924
I'm after log as this will be the volume control for a stereo balanced source.
EDIT: I've check the usuals (farnell and RS) - no joy.
Re: It says LOG
Doh! Well, at least I can order it now, thanks.
dpuopolo said:You get an Alps 6 gang motorised 20k log potentiometer Alps part number RK13613MC00LA.
Nisbeth said:If you do an ebay-search for RK27114* you'll get to a quad-gang blue Alps from an ebay-seller called familygate - try that instead.
/U.
The RK27114 does look better... thanks! I've ordered the 10k one.
