| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 |
#32 |
I'm pretty sure I'm going to order my MOS-FETS from Exicon.
That whole fake transistor things scares me. Is there one reliable source on the internet to get the 2SK1058 & J162? |
#33 | |
#34 |
The 2sk1058's are no longer available from futurlec. The qty available is zero and the link to that parts page is greyed out.
Rick |
#35 |
If you need them, I still have a few hundred.
#36 |
Real ones have markings "MALAYSIA" (very small font size!!) on the ejector pin marks on the front face (where the part no is printed). You can see if you look through a magnifying lens. Weight is also very less as compared to 2SC5200 biolar.
-------------------------------- ESP P101 is very good |
#37 |
What do real ones look like? Any pictures?
#38 |
Banned
Why not just TEST them.
Connect a 24V PSU across D and S with a suitable (10R for example) resistor in series with the Vcc lead. Connect a pot across the same 24V and connect the wiper via a small (220R) resistor to the G. With the pot adjusted to 0V, slowly increase Vg until the device starts to conduct. If youve got a MOS-FET Igs will be virtually ZERO, measure for ZERO volts across the 220R resistor. Keep increasing the pot until Ids starts to get close to the Ids(max) of the MOS-FET. Igs should still be virtually ZERO. If Igs is ZERO (you definitely have a MOS-FET). If Ids can approach Ids(max) then the chances are that you have a genuine MOS-FET of the type that you are expecting. Fakes come in many flavours. A remarked TRANSISTOR will reveal itself by Igs not being ZERO. A lesser device will simply FAIL under this test. NOTE: Device will need to be attached to a heatsink during testing. |
#39 |
hi guys i am going abroad to africa for some considerable time and really looking forward to it but my problem is this... i have a stock of bits for Mosfet amplifers I will not be taking with me this includes some very large transformers over 2kva have 2 pairs they are extremely good quality not the usual lower quality like the "Antrim" or "ILP" more like "Avell Linberg" wrapped in doped material you know the brown stuff not use this site much is there a section where I can offer them for sale? also have a quantity of MOSFETS used but good ones old discontinued Hitachi 2SK/J 82 cannot recall full type but H-paks on sinks 32 of them plus others anyone help me here?
#40 |
This is the legendary fake
| 2SJ162-E and 2SK1058-E | 1965GTO | Vendor's Bazaar | 4 | 26th March 2012 01:38 PM |
| Anyone know where to get 2SJ162/2SK1058 | fossil2k | Solid State | 8 | 17th March 2008 12:07 PM |
| 2sk1058/2sj162 Fs | sandyhooker | Swap Meet | 3 | 12th March 2008 04:50 PM |
| 2sk1058 / 2SJ162 - 4 of each - aus only | mikefromaus | Swap Meet | 0 | 24th January 2008 01:27 PM |
| Fake 2SK1058 or 2SJ162? | ShinOBIWAN | Solid State | 8 | 19th March 2005 04:24 AM |
| Page generated in 0.10768 seconds (71.76% PHP - 28.24% MySQL) with 11 queries |
