Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th February 2003, 11:45 PM   #1
Default Source for Shaft Entenders
Does anyone know a source for some shaft extenders. I am building a project and want to keep the source selector and volume pots in the rear of the chassis.
I do not want to top mount the controls like some of the DIY gear. The shafts are all 1/4", and I need about 8 - 9 inches to get from the front back to the rear panel.
TIA,
George
Old 12th February 2003, 11:55 PM   #2
haldor is offline haldor  United States
Rod sells them on his website.
http://sound.westhost.com/purchase.htm
Phil
Old 13th February 2003, 12:04 AM   #3
yep, rod sells really nice ones. also, peter daniel used 1/4" aluminum bar and some plastic tubing to accomplish the same result for much cheaper. with the tubing, the pot and the knob dont have to be perfectly aligned, and you might even be able to manage curves and angles.
-chris
Old 13th February 2003, 12:13 AM   #4
Default Thanks - I will look into both options.
I am very cheap, the DIY looks interesting, just need to figure out some bushings to support the shafts as they come out of the front panel.
The ESP extenders are most likely what I will get though. The price of 50.00 for three plus shipping from OZ will justify another run through the local surplus shops.
George
Old 13th February 2003, 12:20 AM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
If you are cheap this is the best way to realize extender. Quoted from another thread:
"Sometimes you need extention on a pot, yet a proper hardware is hard to obtain. Just recently I found out that 1/4" plastic tubing for water supply and 1/4" brass rod available from home hardware stores (HD) are perfect for that purpose. You don't even need screws, everything is tight fit."
I used it recently on my Gainclones and it work perfectly. The flexibility of that setup is a real advantage, since usually not everything is always properly aligned.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 13th February 2003, 12:41 AM   #6
Philo is offline Philo  United States
Hi guys, I came upon a cheap solution as well. The tubing works well but on my selector switches and stepped attenuators had a tendancy to slip over time and the marks on the knob were misaligned. These are large board extenders with a .25" ID, .50" OD and two 9/64" holes I drilled then tapped for 10-24 set screws. The flats make it really easy to drill. I get them from a local electronic surplus shop for $.40 each. I think they are pretty easily attainable from a variety of places. I get the rod with 2 opposing flats from him for $.25 ea too, but any .25" rod will work.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 13th February 2003, 05:50 AM   #7
Sorry, large board standoffs.
Philip
Old 13th February 2003, 05:59 AM   #8
diyAudio Moderator Emeritus
roddyama's Avatar
If you absolutely must buy something pre-made here’s a link to a place that sells small parts.
http://www.smallparts.com/
You might also try a hobby shop that has radio control supplies.
Rodd Yamashita
Old 14th February 2003, 03:23 AM   #9
OliverD is offline OliverD  Germany
OliverD's Avatar
Check out this link as well:
http://www.schuro.de/Downloads/PDF-P...sverb_I_BR.PDF
Old 14th February 2003, 11:36 AM   #10
Default Thanks, those look well made and cheap.
The prices are very fair, I can find the shafts and bushings locally, only need the couplers.
George
Where to get pot shaft extension? Dustin Haug Parts 27 16th August 2011 02:47 AM
Can I adapt the shaft of a pot? vvangelovski Parts 7 23rd May 2009 06:15 PM
Where to get shaft extenders r0cket- Parts 6 23rd April 2004 04:02 AM
shaft extender JAZZ2250 Parts 4 7th July 2003 05:01 PM
Page generated in 0.09484 seconds (80.82% PHP - 19.18% MySQL) with 11 queries
