Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th February 2003, 08:10 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default OP Amps pinout, ok. But wich side is the top?
the datasheet is reffering to a point on the op amp, but I haven't this point
so, I don't know if I'm gonna to solder pin 1 or pin 5
Old 12th February 2003, 08:14 PM   #2
Banned
You look on the pinout in the datasheet.
You look from sky like a bird down to the IC. It shows left side a dot or some kind of mark. Left side down to you is pin 1, right side top is pin 5.
http://www.mikrocontroller.net/datasheet.php?tl072
topview.
Old 12th February 2003, 08:18 PM   #3
Philo is offline Philo  United States
Which package are you using? On plastic packages(TO- 220) the pin 1 is on the left. There is usually a dot on the front indicating Pin 1.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 12th February 2003, 08:19 PM   #4
Till, your to fast for me!
Philip
Old 12th February 2003, 08:21 PM   #5
Bricolo's Avatar
it's a so-8 (smd)
I've got no point, no mark on the side!
only the part reference written on the top
Old 12th February 2003, 08:26 PM   #6
Banned
device number?
single, dual?
should be the same as DIP:
http://www.analog.com/UploadedFiles/...P179_279_g.pdf
Old 12th February 2003, 08:30 PM   #7
Bricolo's Avatar
dual
Old 12th February 2003, 08:31 PM   #8
With the lettering right side up and left to right pin 1 is bottom left (if horz lettering). Vertical lettering is top left. Who is the manufacturer? The SO-8s I have replaced are all marked.
Philip
Old 12th February 2003, 08:34 PM   #9
Bricolo's Avatar
it's an AD
there's absolutely no marks, except the writing
Old 12th February 2003, 08:35 PM   #10
Are the pins on the left and right of the lettering or top and bottomof the lettering?
Philip
Mounting speakers side by side jamikl Multi-Way 2 6th August 2007 06:01 AM
Low side driver as a High side fr0st Parts 0 8th May 2004 03:14 PM
Side fire sub, how close can magnet be to side? tim_rule Multi-Way 2 2nd February 2003 09:22 PM
Page generated in 0.07925 seconds (85.67% PHP - 14.33% MySQL) with 10 queries
