| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Banned
look into the AD datasheet in post before. I have one on my hand. You look from top on the writing. left down is 1.
#12 |
P I N S
writing P I N S the lower P is 1? |
#13 |
Yes, till is right, lower left is pin 1.
Philip "If you didn't make it with your own two hands, its not really yours". |
#14 |
Some SO-8s are bevelled along the side containing pin 1.
James |
#15 | |
and some others aren't |
#16 |
it works
thanks a lot, guys! |
#17 |
Banned
If you look very carefully you will see that one side of the IC has a oblique angle. This is the 1-4 pin side. Pins are always numbered counterclockwise, just as the atoms in a molecule, and this will give you a clue which one is number one. I admit I stared quite some time at a AD8611 to figure it out!
| Mounting speakers side by side | jamikl | Multi-Way | 2 | 6th August 2007 05:01 AM |
| Low side driver as a High side | fr0st | Parts | 0 | 8th May 2004 02:14 PM |
| Side fire sub, how close can magnet be to side? | tim_rule | Multi-Way | 2 | 2nd February 2003 08:22 PM |
| Page generated in 0.08004 seconds (73.24% PHP - 26.76% MySQL) with 10 queries |
