Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
PTC resistors for protection of small transformers
Old 24th October 2007, 11:51 AM   #1
roffe is offline roffe  Norway
Default PTC resistors for protection of small transformers
I am looking at certain transformers from Hahn (examples: http://www.hahn-trafo.com/english/ei38.php ), and notice this:
"Primary protection by means of transformer hegt coils to IEC 127 standards or secondarily with PTC resistances".
I must admit that I am pretty new to PTC resistances.
Can someone who knows explain a bit on how to select the correct PTC resistor and implement transformer protection for a specific transformer (schematics or by explanation)?
Old 14th November 2007, 09:19 AM   #2
MaKari is offline MaKari  Finland
Please, check the link: http://edn.com/archives/1996/011896/02df5.htm
Anyway the primary fuse is the must in diy equipment.
Old 15th November 2007, 01:03 PM   #3
fernando_g is offline fernando_g  United States
I agree with MaKari. A primary fuse is mandatory protection.
The problem that I see with PTCs is that their trip point varies substantially with ambient temperature. Therefore, they should be seen as backup protection only, the fuse is always a must.
PTC resistors for protection of small transformersHide this!Advertise here!
Bias Protection Resistors in DC Coupled Amp dsavitsk Tubes / Valves 6 23rd August 2009 01:53 AM
Woofer protection for small monitor Mos Fetish Multi-Way 4 26th April 2009 08:39 PM
A75 protection diodes and Cascode load resistors slogan2112 Pass Labs 1 13th October 2008 10:10 PM
IC/FS: speaker drivers, transformers, opamps, resistors, capacitors, etc. needtubes Swap Meet 1 3rd September 2008 04:44 AM
small transformers? CRFX Chip Amps 16 7th May 2004 04:02 AM
Copyright ©1999-2017 diyAudio
