diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Prower transistor replacements (http://www.diyaudio.com/forums/parts/110364-prower-transistor-replacements.html)
cathode_ray 19th October 2007 03:01 PM
I have an OLD DENON integrated amp (DM300). Distortion on one side. Someone's been in there and replace output devices unlike those on other side. I would like to replace with indenicle part (within reason) and having trouble x-reffing them. Output devices = 2577 and ATT02 (both SK)
I found a replacement for the 2577 - 2SC2578(NPN 140v, 7A, 70W) but can't find one for the ATT02.
thanx,
Ashley
PM650 19th October 2007 11:55 PM
Japanese transistors always (at least all that I've ever seen) have part numbers like this: A949, C2603, etc.. That is to say, a letter followed by 3-4 numbers, sometimes with an additional letter following the part no. to indicate other parameters (2SB649A, 2SD600K, etc.).
The ATT02 is really A1102 (this is the complement to C2577).
The complement to C2578 is A1103.
Very useful site: http://www.datasheetarchive.com
cathode_ray 22nd October 2007 01:54 PM
Thanks so much. I'm a tube guy so this is new territory. I have found some subs but the only A1102(ATT02) is a HAll effect switch... I'll keep searching.
gootee 23rd October 2007 01:46 PM
You do have to put the implied "2S" back in front of the number. i.e. It's "2SA1102". Google.com gave 3470 hits.
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
cathode_ray 25th October 2007 03:57 PM
I've found these parts(matched pairs) from NTE. Is there a better source/brand as I've heard disparaging things about these?
AndrewT 25th October 2007 05:48 PM
Toshiba, Sanyo & Hitachi are good.
Is PMC = Hitachi?
Eva 26th October 2007 12:45 AM
Those transistors are probably obsolete and no longer produced by the original manufacturer, and this means that you are probably going to get fakes, rebranded parts or sub-standard stuff if you buy them (including NTE replacements). Look for modern transistors having similar parameters. Sanken and Toshiba will have nice substitutes. You can try to find threads discussing output transistors with the search engine, there is plenty of info on models and sources.
EchoWars 26th October 2007 11:40 AM
Listen to Eva...these transistors have been obsoleted by the manufacturer for many years. You can just about be guaranteed that anything you find with those numbers will be counterfeit.
Copyright 1999-2017 diyAudio
