Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th December 2011, 02:42 AM   #51
tomlang is offline tomlang  United States
tomlang's Avatar
I have a basic question regarding these. There are two types I see. One is an "all digital" that does not have a volume control knob at all but the volume is controlled up and down "digitally". The other has a motor driven potentiometer.
Are the contacts on the motorized pot version "dry"? In other words, is the pot hooked up to the rest of the circuitry on the supplied pcb or does the pcb circuit simply turn back and forth a pot that has no connections to it so that it may be directed connected to your circuit?
I'm hoping for the latter as I want a remote controlled pot to connect internally to a tube preamp circuit. In other words, connect this motor driven pot to the circuit exactly the same as a manually controlled pot.
Old 13th December 2011, 06:42 AM   #52
pidigi is offline pidigi  Italy
yes. The kit includes also some relays to switch between different inputs, but they are placed on a different pcb than the pot. So you can use it as a simple "pure" motorized alps pot if you do not connect the relay board.
Ciao
Old 26th February 2012, 11:24 AM   #53
Hi guys
I bought on eBAY a "MV02 - 4 WAY REMOTE CONTROL" and can't make it work correctly. The seller can't help me so I hope somebody here can.
Motor works fine in 2 ways when +/- VOL or MON on remote is pushed down. Relays operate well with 1, 2, 3, 4, 5 buttons.
Problem : whatever 1, 2, 3, 4, or 5 button is activated, motor keeps turning endless counterclockwise until I push +/- VOL or MON. This also happens at power ON.
I tried all wiring combinations with CODE SWITCH (I don't knowwhat is the exact fonction of this switch) and even without it : same result.
There is 5.12V DC on AT89C51 20-40 pins, as expected. CODE SWITCH looks like a 3 pins rotary attenuator without stopping position.
I don't know how to solve this problem.
Thank's
Old 7th March 2012, 11:15 AM   #54
Default functions
as far as I know, there are some functions not controlled by any code switch, but by two resistors - R17 & R18. These instructions should be related to the MV-01.
Operation Mode of the Motorize Volume
R18 not install
Every time the Volume will turn to min. and the signal relay is turn on after a short delay of time after you turn on the power of the MV-01.
R18 installed
Cancel the function
R17 not install
Every time you change the Input Channel the volume will turn to min. and the signal relay is turn on after short delay.
R17 installed
Cancel the function
HTH
Ciao
Paolo
Old 7th March 2012, 11:20 AM   #55
Default R17 - R18
on the schematic of the MV06:
R17 connected between pin 28 of U1 and pin 26 of U1;
R18 connected between pin 27 of U1 and pin 26 of U1
Ciao
Paolo
Old 29th March 2012, 12:46 PM   #56
Romanko is offline Romanko  Russian Federation
Send a message via ICQ to Romanko
i've got MV04. A dont need so many inputs, So i want the following: when press the 4 buttons - my amp will turn on and when the 5 - turn off. What should i do with the schematic?
MV04.pdf
DIY Volume Remote Controlled for our GC?? thomgun_lc Chip Amps 11 28th May 2010 11:21 AM
Anyone familiar with this Lite remote volume kit? mattjk Chip Amps 56 2nd August 2009 09:50 AM
help with my volume control, input selector, and other questions jufreese Chip Amps 5 26th March 2009 04:39 PM
remote controllable input selector Faralla Parts 0 18th February 2008 12:50 PM
I need the infrared remote control schematic for motor controlled volume pot noyan Parts 4 24th July 2007 03:05 PM
Page generated in 0.09763 seconds (74.30% PHP - 25.70% MySQL) with 11 queries
