Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Lite Audio MV-01 / MV-06 remote controlled volume/input selector
Old 19th October 2007, 06:01 PM   #11
Nappyhead is offline Nappyhead  Canada
Default Thanks
I have the same kit and have been waiting to hook it up. You made it easier for me. One question, what are the connections between the two boards on the bottom for?
Thanks Again
Old 19th October 2007, 06:05 PM   #12
roffe is offline roffe  Norway
Thumbs up Thanx, Scooby300
Thanx a lot, this was very helpful. I think I will also like to have pushbuttons for input selection on the front of my amp to be able to operate it even without a remote. Do you know if that will be possible?
What are the red, white and black leads soldered between the boards on the underside?
I will not use it as a passive preamp, even if you recommend that. It will be part of an EL-84 based tube preamp. At the time of the writing I am still lacking a lot of components, but I will post more about it when I start building.
My pre will be based on a design by Jan E Veiset as found here: http://www.diyaudio.com/forums/showt...threadid=92081
I am still not quite sure if I have all the info I need for my use of the kit, but I guess I can ask followup questions in this excellent forum later on...
Old 19th October 2007, 08:04 PM   #13
scooby300 is offline scooby300  United Kingdom
scooby300's Avatar
Send a message via AIM to scooby300 Send a message via MSN to scooby300 Send a message via Yahoo to scooby300
Default Re: Thanks
Thanks Again
The wires are the output on the vol pot strait to the output on the relay board why use copper tracks when you can have silver plated copper wire. And there is less connections
You won’t know until you listen
Old 19th October 2007, 08:35 PM   #14
scooby300's Avatar
Default Re: Thanx, Scooby300
NO way that i think of because it uses a rotary encoder for selecting
Old 19th October 2007, 08:43 PM   #15
Default Inputs
I'm just building a box that sits between my pre and power amps. Can I just connect 1 input and just set the selector to number one and just place the switch inside the box and never use it again?
Old 19th October 2007, 09:34 PM   #16
Default Re: Inputs
Why do you want to use the relay board if you need only one input and one output. I guess the volume pot board will be all you need.
Old 19th October 2007, 10:09 PM   #17
Default OK
When I spoke to the vendor he indicated I needed the board, but if I don't I just need to figure out how to connect it directly to the pot board
Old 20th October 2007, 12:16 AM   #18
What did he tell you that you need the relay board for? Maybe if you want to mute or somthing...
Old 20th October 2007, 05:20 PM   #19
Default Transformer?
I am trying to find a good transformer for this kit. What is the minimum VA for a transformer for this kit? The small transformers also have listed two voltages, one for the unloaded transformer and one for the max load transformer.
I have found a 1,9VA transformer which has 9V when fully loaded and 12,9V unloaded. Will that work with this kit?
Old 23rd October 2007, 01:36 PM   #20
scooby300's Avatar
I used this on from farnell 9530428 each secondary gives me about 14vac . one power the vol unit and the other power MF X-LPS.
As for 1,9VA i do not know i would say just try it . If it does not work just try a higher va transformer.
Lite Audio MV-01 / MV-06 remote controlled volume/input selectorHide this!Advertise here!
DIY Volume Remote Controlled for our GC?? thomgun_lc Chip Amps 11 28th May 2010 12:21 PM
Anyone familiar with this Lite remote volume kit? mattjk Chip Amps 56 2nd August 2009 10:50 AM
help with my volume control, input selector, and other questions jufreese Chip Amps 5 26th March 2009 05:39 PM
remote controllable input selector Faralla Parts 0 18th February 2008 01:50 PM
I need the infrared remote control schematic for motor controlled volume pot noyan Parts 4 24th July 2007 04:05 PM
