| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
This 2nd handed oscilloscope's channel 2 is in function but the channel 1 found no reaction to signal input.
The channel 1 can shows the beam line and can be positioned up and down. Is there any link I can download the services manual or schematic? Or could anyone give me some guidance to repair the fault channel. Thanks very much in advance.
#2 |
most common problem with scope inputs is either an open resistor in the attenuator switch, or a blown diffamp transistor. the input amp of an o-scope is very much like in an audio amp, a diff pair with a current source. the diff amp feeds symmetrical VAS stages all the way to the deflection plates. between the input and diff amp, you have a stepped attenuator. if your trace can't be centered on the screen, suspect the amp section. if you can center the trace, suspect the attenuator.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ |
| Oscilloscope BK precision 1477 | Rafael L | Analog Line Level | 0 | 13th June 2009 10:15 PM |
| Problem w/ Sonance 2120...where can i find schematics? | turbo_slug | Solid State | 0 | 23rd May 2008 10:04 PM |
| Kikusui COS6100M 100Mhz 5 Channel Oscilloscope | JoshK | Swap Meet | 0 | 13th September 2006 08:59 PM |
| 20MHZ Dual Channel Oscilloscope and Staco 1.4kva Variac for Sale | krikor111 | Swap Meet | 2 | 18th December 2004 09:56 PM |
| HOW to use a Heathkit Model 10-18 oscilloscope | Dusk | Solid State | 7 | 14th October 2004 11:00 AM |
| Page generated in 0.07264 seconds (67.72% PHP - 32.28% MySQL) with 10 queries |
