| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am learning to use PIC microprocessors and am starting to try to integrate them into projects. I just finished code for a 4 source A/V switch/source select with an LCD display.
I don't have any way to program PIC's yet. I would like to get something compatible with MPLab if possible. I'm a student and don't have alot of money to burn- the Microchip brand programmer costs $160 which is too much for me right now. I was looking to program the 16F877 and similiar chips. Any suggesstions on programmers? Thanks. Brian |
#2 |
This perhaps?
http://www.jdm.homepage.dk/newpic.htm Haven't tried it myself, so I have no opinion on it. |
#3 |
go to www.melabs.com and look to their support page -- you'll find links to the PICLIST -- from there someone will point you in the right direction.
I use a PicSTART Plus -- you should be able to get a student version through your college. |
#4 |
Here's a board from Olimex that is described to be compatible with MPLAB, and that MPLAB even detects it as a PicStart Plus:
http://www.olimex.com/dev/pic-mcp.html Price is $70 (http://www.olimex.com/dev/pricelist.html). There's cheaper boards for $20 also from Olimex if you're willing to use other software. |
#5 |
one of the books by Mike Preydko has a circuit board for a PIC Programmer called "El Cheapo".
#7 |
You have a Russian clone of PicSTART Plus called PICSTARTER + with schematics so you might try to build it yourself
#8 |
Electrons are yellow and more is better!
If you want to try AVR from Atmel their programmers are real cheap. STK-500 costs only 50 USD and the grey ISP-box is even cheaper. (ISP = in-circuit programming)
AVR is faster and cheaper and easier to program (in-circuit) and has better architecture but a little but worse documention. The picture shows the big evaluation board which takes almost every processor.
/Per-Anders (my first name) or P-A as my friends call me |
#9 | |
Also, I'd recomend IC-Prog - it's a windows-based programmer that is a bit easier to use than the DOS programming utilities that come with the JDM programmer... Don't know if it's compatible with MPLAB - I don't use it. Although I've just seen the latest version of MPLAB, and it's *much* better than it used to be... |
#10 |
Thanks for all the replies, I will check all the suggesstions out and look into possibly learning the AVR. I appreciate everyone's help.
Brian |
| ET51 programmer | Garyepe | Vendor's Bazaar | 2 | 24th July 2009 03:55 PM |
| ET51 programmer | Garyepe | Group Buys | 2 | 22nd July 2009 03:08 PM |
| AD21161 Programmer | dmfraser | Digital Source | 0 | 10th August 2004 07:09 PM |
| PIC Programmer: Weird Measurements | Devil_H@ck | Parts | 13 | 20th March 2004 04:41 PM |
| VIACCESS Sat. Card programmer . | darkm4n | Parts | 0 | 29th November 2003 05:52 PM |
| Page generated in 0.10170 seconds (81.58% PHP - 18.42% MySQL) with 11 queries |
