| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
bad idea: I like to built a relay attenuator like the one in the Aleph P, but with 10 bit resolution. Resistors 20k, 10k, 5k, 2.5k, 1.25k, 612, 315, 156, 78, 39. So in worst case the impedance will go down to 78 ohm, at -6dB attenuation. ( 39 ohm to ground and the rest in parallel to input ) My question is: Can I drive this network with a buf 634 on CD-player level (2V) ? I guess, a normal OP is not suitable. If the BUF is ok, what configuration should I use ? Alone ? Inside feedback loop of OP ? Greetings, Bernhard |
#2 | |
On Hiatus
2v/80 ohm is only 25 mA rms that is okay for BUF634 Even a OPA2134 can put out that current, BUF634 is specially made for a little higher power output by the way, those curves of max current output ans max power dissipation is in the datasheet Google: BUF634 datasheet /halo |
#3 |
yes, i have all the data sheets, my OP is an Op27 and this one has a shot circuit current of 25mA, so 25mA for normal operation may not be that good...
2134 would maybe better. |
#4 | |
On Hiatus
This applies also for real life opportunities: Just because you could - doesn't mean you should! To drive any component, resistor, cap, transistor or IC close to its limit is generally not adviceable. Not for good audio-quality operation. Instead we use other components, to take the burdon of the main device. To get better performance, lower distortion ..... /halo - need some help with his burdon - at times |
#5 |
diyAudio Moderator Emeritus
There are better alternatives for the OP27 like it's "brother" OPA627. Or use the BUF634 alone if you don't need amplification.
Sometimes less is more. Mit freundlichem Gruss, Jean-Paul
It's only audio |
| B-1 buffer question | dyohn | Pass Labs | 5 | 1st June 2009 07:18 PM |
| GC buffer question | dsavitsk | Chip Amps | 11 | 10th March 2005 02:10 PM |
| Analog Devices buffer similar to BUF634 | 5th element | Solid State | 0 | 26th July 2004 02:56 PM |
| One more buffer question... | Adam M. | Chip Amps | 18 | 20th April 2004 02:06 PM |
| PGA2310 buffer question | till | Solid State | 5 | 20th September 2003 12:57 AM |
| Page generated in 0.08667 seconds (78.88% PHP - 21.12% MySQL) with 10 queries |
