| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
i have an amp i am currently repairing, and with a lot of help from a fellow forum member, the problem seems to be one of the transistors in the control circuit (power supply). since there aren't a lot of transistors in that circuit the plan is to just replace them all, they are:
2sa949(o,y) quantity 1 2sa970(gr,bl) quantity 1 2sc1815(o,y) quantity 2 2sc2240(gr,bl) quantity 1 tlp508(v) quantity 1 (unlikely this is the culprit, but might as well replace it anyway if i can find it(not available at newark)) my question is the only store that i can find them all at online (ie www.newark.com) have transistors that are close, but not exact for example, i need a 2SC2240(gr,bl) but and only find a 2SC2240 or, i need a 2sc1815(o,y) but can only find a 2SC1815-Y. can anyone help me out with these letters after the transistor number? i have been told they are somewhat interchangeable as they deal with how the leads are positions? google hasn't been any help to me on this one... thanks!! |
#2 |
Magneto the Gravity Man
The letters after the transistor name are gain bandings.
gr=green bl=blue o=orange y=yellow this may give you some idea :- http://www.rfparts.com/tranmatch.html Otherwise they are the same transistor. Andy |
#3 |
If the schematic mentions two hFe classes it means you can use either one.
Also means that you are not supposed to use a device with an hFe class other than those mentioned. So, either O or Y grade, and either GR or BL grade. The O and Y hFe grades overlap eachother, so do the highest GR and BL grade. O is up to 140, Y lower than 240, GR can go as high as 400, BL devices are the best and can have hFe values as high as 700. TLP508 reads as a LED optocoupler, those come in diferent grades too.
Looks like Sponge Bob has killed another thread. |
#4 |
Why not test them and only replace the bad one? This little guy won't set you back much and does the job.
http://www.harborfreight.com/cpi/cta...emnumber=90899 |
#5 | |
then we can sort out the correct class. considering the price of the transistors, ill still probably replace what i can, but it would be nice to confirm this is the problem. what i dont get is when i find the transistors listed online, they dont list a hFe class for them, if they dont list a class, does it mean they dont have them and they are wrong? or would i have to track down the manufuactors specs for it to find the correct class? |
#6 |
very few vendors tell you what hFE class their stock is. The exception are the BC5xx series that are commonly specified with suffix b or c. The datasheet for each transistor will tell if the transistor is available with pre-selected hFE grades and what letter codes are used. Many amplifiers will work with any grade in any position, but some specifications can be improved if a more precise gain is specified.
regards Andrew T. |
#7 | |
#8 | ||
i though for sure this was the problem, oh well back to trouble shooting (and soldering all these transistors back in! )
#9 |
Before you do that, post a circuit diagram and the symptoms.
Someone may be able to help. Andy |
#10 |
Don't solder them back in yet. Have you checked all six combinations of the two leadout test? C-E, E-C, C-B, B-C, B-E, E-B. Have you got a 10k to 100k resistor and a 1k0 (or nearby)? You can check the transistor gain with these and a 9V battery.
regards Andrew T. |
| 3 transistor amp | jjac7212 | Solid State | 8 | 24th April 2008 06:29 PM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| who knows this transistor? | d.O.LF | Solid State | 16 | 5th March 2007 08:46 AM |
| Transistor ID | EchoWars | Solid State | 8 | 13th November 2004 07:08 PM |
| Page generated in 0.12853 seconds (82.51% PHP - 17.49% MySQL) with 10 queries |
