| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm upgrading the caps in my tube pre-amp with some teflon V-Caps and would like to use some MultiCaps (same values) as well... good or bad??
#2 |
no manufacturer makes the best caps in ALL categories/types. Just like a frying pan manufacturer does not necessarily make good automobile tyres. Swap around from manufacturer to find the poor combinations and better combinations. It is MUCH more important to use the correct type of capacitor for each different duty.
regards Andrew T. |
#3 |
I would suggest that you start out buying a handful of decent quality, high voltage polypropylene caps and using them to bypass your existing caps. If space is not a problem, go for really high voltage caps (1600v/2000v snubber caps work well). Otherwise, you could end up spending a great deal of money on so-called audiophile caps and not like the results. Even if you still decide to go for high priced caps afterwards, you will still benefit in almost all cases from intelligent bypassing. Just remember, though, that you need to let caps run in before making any final decisions about them. Some caps can sound awful when new, but eventually smooth out and become winners. Just my 2c worth.
#4 |
Sorry, I didn't read your original question clearly. IMHO - good. Mix and match is my motto.
#5 |
Hey cats... thanks for the suggestions and comments
#6 |
I'd go with mix and match as well.
The V caps are undoubtedly some of these best that you can buy but as with all caps they have their own character. Even with the V caps if they were used exclusively you might not like the results. Russian K40Y caps are quite nice as well as affordable. You can also track down some Vitamin Q caps on Ebay if you like the sound of PIO caps. Same thing with them as well though, use a good quality film and foil as well as PIOs. Film and foils generally out perform metalized polys. Lar |
#7 |
You could also try Russian FT-3 teflon caps. Some people like them although I haven't tried them myself. These are pretty cheap for teflon. ebay to find them.
| Vandersteen X-2 X-over redo, Caps brand? | joster | Multi-Way | 3 | 17th May 2012 02:07 AM |
| input coupling capacitor VALUE & BRAND for mono LM4780 | nickthevoice | Chip Amps | 4 | 13th May 2008 12:57 PM |
| Unknown Capacitor Brand? | bigparsnip | Parts | 1 | 13th May 2003 07:53 PM |
| McIntosh brand caps | Gabster | Parts | 7 | 13th January 2003 01:19 AM |
| Page generated in 0.08384 seconds (73.75% PHP - 26.25% MySQL) with 10 queries |
