Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th October 2007, 09:44 AM   #1
CJ900RR is offline CJ900RR  Sweden
Default Replace 1N456A
I would like to replace National's 1N456A (low leakage diod) because I dont have them at home.
I have a bunch of others though, like:
1N4004
1N4007
1N4148
1N4935
1N4937
Im thinking 1N4148 would do the job. Is that correct or do you think I should go with one of the others?
Old 8th October 2007, 11:31 AM   #2
acid_k2 is offline acid_k2  Italy
If the use of 1N456A is not critical, 1N4148 should work.
Old 8th October 2007, 12:36 PM   #3
Well it's for a DC-servo, the one in National's AN-1192 pdf.
Old 9th October 2007, 07:36 AM   #4
For DC servo, 1N4148 will work.
another solution in:
Gainclone for subwoofer
replace DAC maxpou Digital Source 13 21st February 2008 05:51 PM
replace 5y3 ardan77 Tubes / Valves 5 15th January 2006 03:41 AM
Replace of CDM 4/19 with CDM 4/31? bezobraznia Digital Source 4 14th November 2005 03:56 PM
what do I replace...? 9am53 Tubes / Valves 10 5th May 2005 02:20 AM
Page generated in 0.06963 seconds (69.98% PHP - 30.02% MySQL) with 10 queries
