Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th October 2007, 10:46 AM   #1
Onvinyl's Avatar
Default Source or replacement 2sa872
I need adequate replacements or a reliable source for the mentioned Q's. The npn complement seems to be still available.
Apart from low noise, the low Cob seems to be the major feature I need.
thanks for some input,
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 7th October 2007, 12:31 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
2SA1208, 2SC2910, Farnell.
/Hugo
Old 7th October 2007, 01:21 PM   #3
Default Re: Source or replacement 2sa872
Hitachi use 25V for Cob, you must use the graph to compare to other devices.
Look at 992, 1370, 1406.
regards Andrew T.
Old 7th October 2007, 01:37 PM   #4
This company can supply the 2SA872.
www.cypax.dk
http://www.cypax.com/servlet/oase.ar...nr=01.003.0872
www.newclassd.com
Cyrus One - problem with new 2SC1775/2SA872 lightning999 Solid State 4 19th February 2011 12:49 PM
HELP! Trying to source replacement tweeters for TDL RTL3s paulspencer Multi-Way 1 25th June 2009 06:40 AM
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 08:19 PM
Interesting: a source of replacement styli from japan federico moreno Analogue Source 1 28th September 2005 06:54 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Page generated in 0.08042 seconds (68.60% PHP - 31.40% MySQL) with 10 queries
