| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#2 |
#3 |
cap?
#4 |
I doubt it. I think its the diode array bc it goes straight from 12vdc source.
Can someone confirm? |
#5 |
I could be wrong, but it sure looks like a filter and I'd expect one on the input to a HID light power supply.
Those "chips" look like double barrelled ferrites. then there is that little capacitor in between them from positive to negative. It would be to stop noise from the switching in the step-up power supply from getting out. After those will be a pick-off for some power for the smarts, a low ESR, high ripple current capacitor and a big fat track to a big fat chopper transistor. after that a small transformer then big voltages after that. I think that transistor has dies and blown the links in the power supply. I suggest checking the vehicle wiring and see how over-rated the fuse (if any) is. If all looks well does the vehicle have a HF radio antenna on the front barwork? check the antenna earth. Something else might be grounding itself via the HID light's ground. Be very careful, that power supply can easily hurt you. |
#6 |
I agree, these parts are dual inductors, RF filters.
I use to feel like the small child in The Emperor's New Clothes tale |
#7 |
Also, if I am able to power the ballast by grounding the actual case/chassis and 12vdc+ to the wire.
If I were to purchase on mouser.com, what do I look for? Thanks, |
| Fuse housing melting but fuse not blowing, ppi amp | rawadia | Car Audio | 21 | 2nd August 2008 10:39 AM |
| SMD Fuse | stef1777 | Parts | 2 | 26th April 2007 12:03 AM |
| Why main fuse and not rail fuse? | digital desire | Solid State | 10 | 3rd December 2006 08:07 PM |
| amp rating for fuse and fuse holder? | riotubes | Parts | 5 | 27th August 2006 03:10 AM |
| Page generated in 0.07828 seconds (76.57% PHP - 23.43% MySQL) with 10 queries |
