Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th February 2003, 03:30 AM   #1
Default Hammond vs. Marshall Transformers
I'm building a near copy of a Marshall JCM800 2203 (100W).
But I don' t want to spend the money to get a Genuine Marshall Power Transformer.
How can I determine which, if any, of the Hammond transformers will drop into the circuit without having to make modifications?
Also, does the Power transformer have much effect on sound, appart from sag?
Old 10th February 2003, 03:53 AM   #2
seangoesbonk's Avatar
Most replacement parts are a bit of a ripoff.
Do you have a schematic of what you are building? That will help us determine a match, if any.
How much does the Marshall transformer cost?
With an amp like the one you are building, I wouldn't expect any noticeable sound difference provided the transformers have the same ratings.
My girlfriend's sub is bigger than mine...
Old 10th February 2003, 04:08 AM   #3
The Marshall replacements are:
HollandAmps = $147.
Angela.com = $155.
The Hammond 273BX from AntiqueElectronics = $58.
(I read at a site that was out of stock that the 273BX can be used for "British amps including Fender and Marshall")
That seemed a bit vague to me.
Old 10th February 2003, 04:12 AM   #4
This is the Preamp.
The Power amp won't be modified, and the Pre will only be modified in filtering.
hammond transformers? ipop07 Tubes / Valves 21 14th June 2011 04:00 AM
Hammond Driver transformers poynton Tubes / Valves 6 27th August 2007 05:01 PM
hammond transformers eitanwaks Swap Meet 0 13th May 2007 10:20 AM
Hammond Transformers Ham Swap Meet 2 16th March 2007 11:45 PM
Hammond Transformers Gabevee Tubes / Valves 0 5th April 2004 03:47 PM
Page generated in 0.10037 seconds (62.57% PHP - 37.43% MySQL) with 11 queries
