| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I bought a Velleman 7W mono amplifier a while back (the one shown here) with the intention of making a small portable amp/speaker box to use with my iPod. Can anyone recommend a good-sounding speaker to use with it? Apologies if this is a rather amateurish question. I just discovered this site and it seems like something that I could really get carried away with, but I guess I have to start somewhere. And also, could anyone recommend a second project, after I finish this little one?
Many thanks in advance. |
#2 |
Have a look around the Fullrange forum as there are plenty of speakers to be had. Look for some using the Fostex FE127E (maybe FE107E) or CSS FR125S as are a good drivers to kick off in the hobby.
A good place to start for amps would be in the Chipamp forum and look at some using the LM3875 or LM3886. Good chipamp kit suppliers are members of this forum: http://www.audiosector.com/ http://www.chipamp.com/ |
#3 |
[QUOTE]Originally posted by rabbitz
[B]Have a look around the Fullrange forum as there are plenty of speakers to be had. Look for some using the Fostex FE127E (maybe FE107E) or CSS FR125S as are a good drivers to kick off in the hobby. Thanks for the reply. Do you think those speakers could be driven by the amplifier that I linked to? Its specs indicate music power output of 7W / 4ohm and RMS output of 3.5W / 4ohm or 2W / 8ohm. Will I be able to do anything with this, or should I just forget about it and get a more powerful amplifier? This first project doesn't need to be super high quality, just a little speaker box that I could maybe run from batteries and take out in the yard. |
#4 |
Have a look at some on eBay and look for something with an SPL 90dB or more. Even with low power output, should give enough volume.
If you need a tad more power at a cheap price, have a look at the Sonic Impact T-Amp.... a bargain. |
| Speaker recommendation... | T^2 | Full Range | 15 | 28th December 2007 10:09 PM |
| Speaker recommendation | Netlist | Multi-Way | 16 | 21st June 2007 07:33 PM |
| Speaker Recommendation Please | Joshkun | Multi-Way | 20 | 10th May 2007 09:23 PM |
| Need Speaker Recommendation | jwags818 | Multi-Way | 1 | 17th August 2005 03:19 PM |
| Page generated in 0.09352 seconds (73.09% PHP - 26.91% MySQL) with 10 queries |
